Looking for a sound card that can handle oscilloscope music.
Solved by da na,
3 minutes ago, My_Computer_Is_Trash said:Ah, you can do it on virtual oscilloscope software. Although my integrated sound card AC'97 is doing fine right now. I'm doing something specific that needs the sound waves to be represented extremely accurately on a oscilloscope. I cannot really tell you more as I am currently writing a thesis that has to do with this matter.
Oh neat!
Well, if you're looking for PCI I have to recommend a classic Sound Blaster, but I have a feeling you need PCIe and modern drivers. Sound Blaster Z has served me quite well, around $100 new but you can get them even cheaper used.
