15 minutes ago, VINCEindaHOUSE said:
Been having crashing issues and ran memtest and im getting errors. I find it hard to believe that I got 4 bad ram sticks. what are the chances its the mobo or cpu causing the problem
If you are are running 4 sticks, only 1 may be bad or only 1 slot could be bad on the motherboard.  Try to run the test with 2 sticks and then 1 stick ( Switching sticks if one crashes to see if others are good, switch slots too )  Until you find the one that might be faulty. Process of elimination.
https://linustechtips.com/topic/1500636-mem-issues/#findComment-15891288
I have been slot 1 just shoots of hundreds of errors and the other slots seem ok unless you let memtest run longer and then I still get errors
https://linustechtips.com/topic/1500636-mem-issues/#findComment-15891298
What motherboard, cpu do you have and what ram did you buy? Give me the exact ram number.
https://linustechtips.com/topic/1500636-mem-issues/#findComment-15891322
4 minutes ago, VINCEindaHOUSE said:
BSOD, game crashes and forces the pc to restart. if i run memtest a bunch of errors pop as well
Okay I experience the same exept from when I run mem test it dosent find any issues.. I startet after I added another 32gb of ram to my system.. going from 2x16 to 4x16.. I was actually hoping to find ram issues.. but now im kind of lost..
https://linustechtips.com/topic/1500636-mem-issues/#findComment-15894790
