Download GPU-Z and check thermal for your GPU and CPU in the sensor tab.
https://linustechtips.com/topic/1500463-help-fps-problem/#findComment-15890007
31 minutes ago, Clinax said:
This what you guys mean?
Can u resize the window so it will show all sensors?
Also take screenshot while the gpu is on load. Play game or something in the background.
https://linustechtips.com/topic/1500463-help-fps-problem/#findComment-15890152
