motherboard Finding a motherboard that supports 2 GPUs at full PCIe speed for AM5
9 minutes ago, Blaspheme said:Sorry about that, new to the site.
I also think I finally found a motherboard that suits my requirements, but would appreciate some feedback, just to make sure I'm on the right track.
Found this: https://www.msi.com/Motherboard/MPG-X670E-CARBON-WIFI/Specification.
It's the MSI MPG X670E CARBON WIFI.
As far as I can tell, it supports a configuration of: x16/x0/x4, x8/x8/x4
over the 3 onboard PCIe x16 slots.
From the chart above, as far as I understand this motherboard should be perfectly compatible with my requirements of running 2x GPUs.
Am I correct in my thinking?
This motherboard only supports x8 per GPU when 2 are used. And since your GPU's won't support PCIe 5.0, they will run in PCIe 4.0 x8. But most GPUs have minimal performance loss when only running at x8 speeds on PCIe 4.0.
