Hi Guys,
So I'm thinking of going for a new build (just cause I can), my current build is an M-ITX so I'm going to go for an M-ATX build this time as I would like to SLI in the future, the parts i have decided on are as follows:
Asus MAXIMUS VI GENE
Asus GTX 780 Ti DIRECT CU II OC 3GB (Will SLI eventually)
Samsung 840 EVO 1TB Basic SSD - Storage Drive
Samsung 840 EVO 250GB - Boot Drive
Corsair Obsidian Series 350D Performance Micro ATX Case with Windowed side panel
Corsair H100i
Corsair AX860i
The problem I have is that I'm not sure whether to go for the Corsair Vengeance Pro found here - http://www.scan.co.uk/products/8gb-(2x4gb)-corsair-ddr3-vengeance-pro-series-red-pc3-19200-(2400)-non-ecc-unbuffered-cas-11-13-13-3
Or the Kingston Hyper X Fury in either black or red found here - http://www.overclockers.co.uk/showproduct.php?prodid=MY-168-KS&groupid=701&catid=8
Question is 1) What peoples input as to the hardware? Anything you would maybe change?
                   2) It's safe to say I'm going for a black and red theme here, would the Corsair go better or the black/red Kingston Furys??? If anyone has any pictures of the Kingstons in that motherboard it would be great to take have a look, i love the RAM just not sure if they will go as well as the Corsair in that motherboard. I should note I will be buying two lots of 8GB so I can fill all the slots as well.
Decisions, decisions, hit me with your best shot  :P
Corsair Obsidian 350D Chassis / i7 4790K @ 4.0Ghz / Asus Strix GTX 970 / 16GB Red Corsair Vengeance Pro @ 1600 Mhz / Asus Maximus VII Gene / Corsair H100i CPU Cooler / Crucial 250GB SSD / Crucial 480GB SSD / Seagate 1T Barracuda 7,200 RPM SATA III / Seasonic G750W PSU / ASUS Vulcan Headset / Corsair M65 / Corsair K70  / Razer Vespula Mouse Mat / 2 x 22" LG 22EA63 Monitors @ 1080p / 1 x 24" BenQ 144 Hz Gaming Monitor -   :P
https://linustechtips.com/topic/149995-memory-help/
