Hello Everybody,
I recently updated my motherboard/cpu on my PC. Prior to this, my Xbox controllers had a stable bluetooth connection and never ran issues into disconnecting. However, I am now experiencing the issue. Searching online, I found out that it could be a variety of things. This included updating drivers, which I have since done, as well as uninstalling NVIDIA G-Force, which I have also done. The main thing to check was the controller's firmware which was also updated. I have also forgotten the controllers using device manager and reconnected. Still, I am having the same unstable connection. I never ran an issue like this prior to the motherboard changes so I know that the controllers are totally fine. The PC is in the exact same location, in the exact same case. I have absolutely no clue what is going on. Any suggestions?
https://linustechtips.com/topic/1499803-xbox-controller-has-unstable-connection/
-> Moved to Troubleshooting
Assuming you are talking about Xbox One controller. Which motherboard? You are using dongle or built-in bluetooth?
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
