Sup Gamers,
So I have been having this Problem a few days now. My CPU Clock speed drops while gaming down to around 1.0-1.3 GHz, but it should be around at least 3.3-4.0 GHz. Of course my Frame rate drops aswell down to 10–0 fps.
This happens in games like CS:Go and Rainbow six siege, but not in OSU!
I had this build a year or more without problems.
So I have a huch that I fired my CPU or something, cause before this started I played around with Ryzen master and crashed my pc pretty bad, didn't even get a blue screen (I think). And I think after that my Problems began. But on the other Hand, I played around with Ryzen Master even before that and crashed it, but didn't get any problems. I hope some drivers or so got messed up cause of the crash, and it's not that bad. But I don't know.
Also, there have been changes with my Internet lately, my Wi-Fi/Wlan-card, which supports 5.GHz, doesn't want to connect and see 5GHz Wi-Fi. So I got a Dongle which works. I don't think this is the Problem, but when I tried to play Cs:go with no Internetconection with bots only, I didn't have any frame or CPU drops!
My Specs:
Ryzen 5 3600X
Corsair Vengeance 32 GB of, 2400Mhz
Palit RTX 3060
MSI B450M PRO-VDH MAX (Motherboard)
So if anyone knows something, pls HELP!🙏🙏🙏
https://linustechtips.com/topic/1499463-cpu-clock-speed-drops-while-gaming/
Try updating to the latest BIOS and doing a reinstall of the Ryzen Master program and if there is an option to remove settings and profiles do that.
After updating your BIOS you should be able to enable PBO on this chip and that is what I would recommend. Wouldn't touch much of any other setting.
Well I tried that. I updated the BIOS excatly how you should. It said it's installing, I was gone for 30s and i got a blackscreen. It wouldn't start, so I did a hard BIOS reset with the little jumpers. And still blackscreen.
So i fuked up my Motherboard for good.
I'll be buying a new one shortly, which will have usb flashback.
