Surface Pro 2
Go to solution Solved by Volbet,
Yes you can. The Surface Pro uses the X86 platform so you can install pretty much every Windows OS and Linux distro on it.
How it is done I don't know, sorry-
I have a quick question, can I install my own version of windows on the tablet? I have an enterprise version of the windows 8 and would like to replace what is currently on there. Please only answer if you know for certain of an answer as I would not like to waste time on guesses (sorry, I hate how that sounds but its true).
https://linustechtips.com/topic/149941-surface-pro-2/
Nova doctrina terribilis sit perdere
Audio format guides: Vinyl records | Cassette tapes
https://linustechtips.com/topic/149941-surface-pro-2/#findComment-2004229
Yup, it can be done but you will need to download the drivers for the tablets components to work.
https://linustechtips.com/topic/149941-surface-pro-2/#findComment-2006938
