AMD Ryzen 9 7900X and MSI PRO B650M-A WIFI - EZ Debug CPU Light - Red
Solved by chiller15,
40 minutes ago, 191x7 said:Is the RAM in the correct slots?
Tried with a single RAM stick?
Is the RAM on the QLV list of the motherboard?
I've got the RAM in slots A and C, which are the traditional dual channel configurations. Using one stick or no sticks at all doesn't change the behaviour.
Both the CPU and RAM modules (CMK32GX5M2B5600C36) are listed as compatible products.
Update:
Using RAM slots A and B made it post after about 30-40 seconds.
Update 2: Checking the manual states the recommended RAM slots used as B/D for dual channel and B for single. Using slots B/D allowed for a sucessful boot.
Clearly this was a case of RTFM and my old knowledge of using slots A/C!
Edit: Thanks for the assist @191x7
