Removing front panel 760t
Go to solution Solved by Richie,
This was solved over on Overclock.net if anyone is interested, link below!
All credit to jchap1590(http://www.overclock.net/u/227585/jchap1590) from the 760t owners thread over there! Great help, and is gonna let me do the exact mod I wanted without having to "buy and try"!
http://www.overclock.net/t/1472083/corsair-760t-owners-club/350#post_22243403
Hey guys whats up,
Quick question for anyone who owns a 760t!
Is it possible to completely remove the front panel on the 760t? and if so, can anyone post a photo of it?
I want to pick up a 760t, but only if I can completely remove the front panel, dremel out the solid plastic and drive bays, paint it and then use modders mesh across the entire area! The plan is to put a 360 rad in the front!
So guys like I said, pictures would be a massive help! The mods here have been brilliant, and I'll be sure to post when I'm finished mine!
https://linustechtips.com/topic/149860-removing-front-panel-760t/
  • 11 months later...
Thats what I presumed, but I could not find a single photo of it online! haha better safe than sorry!
Hey richie just saw the post you made on OC.net forum just wondering was it easy to remove? Did you need to remove the rivets or smthing ?
"You allowed Sub-Zero to escape. Now, you will suffer my wrath."
