fan headers
Go to solution Solved by NorKris,
yes you can. its called dc control or volt control
33 minutes ago, GOATWD said:
can i plug a 3 pin fan into a 4pin headder and still have speed control over it
no. the fourth pin is used to control the speed of the fan. Without it the fan will always run at full speed.
Have you tried turning it off and on again? Maybe Restart it?
Please make sure to Mark the Solution as a Solution.
Take everything I say with a grain of salt. I could be just about wrong as I am right.
Main RIG
13600K (Undervolted) +MSI Z690 Edge Wi-Fi+ Team Elite 32gb RAM (3200) +Noctua Nhd-15 Chromax Black+ Intel 670p 1TB SSD+ EVGA FTW Nvidia RTX 3090+ Corsair Crystal 465x case+ EVGA SuperNOVA 650W PSU.+ ASUS VP222 Gaming Monitor
Laptop for School: Surface go 2 (sucks ass)
Laptop for tinkering: Dell Inspirion 3358
Audio: Apple Airpods Pro (1st Gen)
(Apple_reigns_ supreme_ forever_ and_ ever)
(I am 16 years old and don't know shit about fucking shit.)
Everyone must suffer one of two Pains: The pain of Discipline or the pain of regret and disappointment.
-Jim Rohn
https://linustechtips.com/topic/1498558-fan-headers/#findComment-15876846
6 minutes ago, GOATWD said:
ok thx
he doesn't know what he's talking about.... you absolutely can. most motherboards even default to DC control rather than PWM unless they detect something on the sense pin.
Primary System
  • CPU
    Ryzen R6 5700X
  • Motherboard
    MSI B350M mortar arctic
  • RAM
    32GB Corsair RGB 3600MT/s CAS18
  • GPU
    Zotac RTX 3070 OC
  • Case
    kind of a mess
  • Storage
    WD black NVMe SSD 500GB & 1TB samsung Sata ssd & x 1TB WD blue & x 3TB Seagate
  • PSU
    corsair RM750X white
  • Display(s)
    1440p 21:9 100Hz
https://linustechtips.com/topic/1498558-fan-headers/#findComment-15876862
1 hour ago, GOATWD said:
thx u to
in bios you can manually force it to use one or the other if the motherboard doesn't detect correctly the type.
Primary System
  • CPU
    Ryzen R6 5700X
  • Motherboard
  • RAM
  • GPU
    Zotac RTX 3070 OC
  • Case
    kind of a mess
  • Storage
  • PSU
  • Display(s)
    1440p 21:9 100Hz
https://linustechtips.com/topic/1498558-fan-headers/#findComment-15876970
2 hours ago, NorKris said:
misinformation
How?
Main RIG
-Jim Rohn
https://linustechtips.com/topic/1498558-fan-headers/#findComment-15877016
13 hours ago, FI Fheonix said:
How?
3-pin can be plugged into 4-pin header.
I've been using computers since around 1978, started learning programming in 1980 on Apple IIs, started learning about hardware in 1990, ran a BBS from 1990-95, built my first Windows PC around 2000, taught myself malware removal starting in 2005 (also learned on Bleeping Computer), learned web dev starting in 2017, and I think I can fill a thimble with all that knowledge. 😉 I'm not an expert, which is why I keep investigating the answers that others give to try and improve my knowledge, so feel free to double-check the advice I give.
My phone's auto-correct is named Otto Rong.🤪😂
https://linustechtips.com/topic/1498558-fan-headers/#findComment-15877640
7 hours ago, NorKris said:
what you told him was wrong.
Can you explain why if your so smart?
Main RIG
-Jim Rohn
https://linustechtips.com/topic/1498558-fan-headers/#findComment-15877653
you wanna know why controllers and MB manufactures let you control the speed with les than 4 pins?
2pin Fans: a controller/MB software can be set to a curve based on volt to control the Fan, with 2 pins you dont know how fast its spinning but this is not needed to control it
3pin Fans: a controller/MB software can be set to a curve based on volt to control the Fan while the fan reports back to the controller/MB what speed its spinning
4pin Fans: The Controller/MB gets another option to control the Fan by pushing 12v all the time but telling the device how often it should use the 12v(PWM), while the Fan is reporting back.
Fan splitters 4pin: only 1 fan reports back what the speed of the fan is. but all of them gets the signal (PWM) on the 4th pin)
https://linustechtips.com/topic/1498558-fan-headers/#findComment-15877665
If I remember correctly, a PWM Fan can be plugged into a 3-pin header, but then it's just like a 3-pin fan.
 Is pulse wave modulation a fancy way of saying frequency modulation but specifying it's through pulsing?
Daisy chaining is just another form of splitting, right?
https://linustechtips.com/topic/1498558-fan-headers/#findComment-15877691
not so sure about that. PWM is the control where 12v to the device turns off and on fast (or not so fast for low speed or full speed)
yep
https://linustechtips.com/topic/1498558-fan-headers/#findComment-15877786
frequency modulation is non specific. it could be done on both analogue or digital systems for different tasks. FM radio is famously Frequency Modulation.
but PWM as a control technique is a digital technique that does not modulate the frequency, so it's not FM. it's not used to store the data signal, it is just a control signal. it tells the thing at the other end of the wire to turn on and off in sync with it. it's just flicking the light switch really fast. and the thing that is modulated to change in PWM is the length of time the signal stays on vs off. as a percentage, because you can't be more turned on than all the time (i've tried...)
it's used in digital light diming (when the carrying frequency is too low it bothers many people because they can feel the flicker) it's used in speed control systems and it's used in controlling the heat elements on your cooktop and ovens. it can also be used in charging circuits and many other palces.
Primary System
  • CPU
    Ryzen R6 5700X
  • Motherboard
  • RAM
  • GPU
    Zotac RTX 3070 OC
  • Case
    kind of a mess
  • Storage
  • PSU
  • Display(s)
    1440p 21:9 100Hz
https://linustechtips.com/topic/1498558-fan-headers/#findComment-15878766
LOL!
Thanks for the research and explanation!
https://linustechtips.com/topic/1498558-fan-headers/#findComment-15878899
