Brothers hard drive recently started making clicky sound.
Google says its probably a head crash. He says the computer hasn't been bumped of wacked recently for it to happen. It just randomly started when he turned on the computer The drive wont show up in bios or windows either. Would there be any options for recovering data from it or fixing the problem?
https://linustechtips.com/topic/1498440-hard-drive-not-working/
is this while doing something intensive (like reading or writing a lot of data?)
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1498440-hard-drive-not-working/#findComment-15875791
https://www.harddrivefailurerecovery.net/is-your-hard-drive-making-a-clicking-noise/ says 'This hard disk based noise, which can also sound like a “buzzing”, can be a major sign indicating that your hard disk is going to crash. No matter which brand of hard drive you own, it is important to back up your data as soon as possible if you hear this sound
Back up your data first
Total: £1040.95
https://linustechtips.com/topic/1498440-hard-drive-not-working/#findComment-15875792
he is unable to do that as it does not show up on the computer at all
https://linustechtips.com/topic/1498440-hard-drive-not-working/#findComment-15875793
doesn't sound good then, has he made sure that the sata cables (both power and data) are plugged in correctly? Also how old is the drive?
Total: £1040.95
https://linustechtips.com/topic/1498440-hard-drive-not-working/#findComment-15875797
All the cables are plugged in and working. The drive was brought new about 3.5 years ago
has he recently installed anything on the drive (if its not showing up its either failed or its a virus)
Total: £1040.95
https://linustechtips.com/topic/1498440-hard-drive-not-working/#findComment-15875802
