Budget (including currency):
Country: Hungary
Games, programs or workloads that it will be used for: Gaming (God of war, FFVII remake, Tomb Raider, Future Final Fantasy titles)
I'm doing a system upgrade for my GF. She already has a AMD 6750 XT GPU but the CPU got left behind last time (i3 8th gen I think). The main gaming display is a 4k TV but 2K resolution is enought (there are 2 otehr monitors for FPS games and occasional programming)
I'm looking to buy a PSU for the new PC setup. It will have a AMD 6750 XT (it needs 2x8pin PCIe connectors) and a AMD 7600X
The two options I came up with are:
BE QUIET! Straight Power 11 Gold 550W
Local shop for price: Shop
BE QUIET! Pure Power 12 M 650W
but the Pure Power 12 only has a split PCIe connector that is not the new ``12vhpwr`` so I wonder how big of a problem it is if I use the split cable
https://linustechtips.com/topic/1498331-help-with-psu/
Country: Hungary
6750 xt defo doesn't need 12vhpwr connector (thats only for the 40 series currently). Its a better bet for you to go with a 650watt or even a 750 watt psu if you can, never underspend on your psu, as a wise man by the name of linus sebastian once said in one of his many live streams
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1498331-help-with-psu/#findComment-15875061
Always look at the GPU designer's minimum recommendation to start with. In this case, it's 650W. Now to find the best 650W or over PSU, a good resource that many use is the Tier List found over at the Cultists Network. Basically, Tier A will be the best and Tier B good for budget, midrange builds. You can sometimes find really great deals online on Tier A PSU's.
https://linustechtips.com/topic/1498331-help-with-psu/#findComment-15875065
