Budget (including currency): +/- 1100€
Country: Luxembourg
Games, programs or workloads that it will be used for: rendering blender, light programming, 3d printing
Hey friends,
I'm only used to building gaming rigs, and they are able to handle the workloads that would be thrown at them. But i need help selecting a system specificaly for rendering and programming.
Budget would be +/- 1100€
I'm open to suggestions :)
https://linustechtips.com/topic/1498246-need-help-with-components/
AMD has an advantage here, not much but still ahead nonetheless.
As for your budget: you may be able to get a used Threadripper system, which would be a good choice for a workstation. Alternatively, the Ryzen 9 7900X (AM5) on a X670 mainboard with 2x32GB RAM and a decent 2TB PCIe Gen 4 NVMe drive is a good start. Case, cooling and peripherals to suit your taste.
"You don't need eyes to see, you need vision"
(Faithless, 'Reverence' from the 1996 Reverence album)
You absolutely want to have a GPU acceleration down the bat on Blender but honestly that would be a great one if OP isnt tight on active cash flow and can quickly spare cash for an RTX 3050.
PCPartPicker Part List
CPU: AMD Ryzen 9 7900X 4.7 GHz 12-Core Processor  (€424.95 @ Megekko)
CPU Cooler: Deepcool AG620 67.88 CFM CPU Cooler  (€58.85 @ Megekko)
Motherboard: MSI PRO B650-P WIFI ATX AM5 Motherboard  (€204.95 @ Azerty)
Memory: G.Skill Ripjaws S5 32 GB (2 x 16 GB) DDR5-5600 CL28 Memory  (€143.90 @ Amazon Netherlands)
Storage: Western Digital Black SN770 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (€128.90 @ Amazon Netherlands)
Case: Fractal Design Focus 2 ATX Mid Tower Case  (€79.90 @ Amazon Netherlands)
Power Supply: NZXT C750 (2022) 750 W 80+ Gold Certified Fully Modular ATX Power Supply  (€108.85 @ Azerty)
Total: €1150.30
Generated by PCPartPicker 2023-04-02 11:46 CEST+0200
If not?
CPU: AMD Ryzen 7 5700X 3.4 GHz 8-Core Processor  (€204.85 @ Megekko)
CPU Cooler: CRYORIG H5 Ultimate 76 CFM CPU Cooler  (€37.02 @ Amazon Netherlands)
Motherboard: ASRock B450 Steel Legend ATX AM4 Motherboard  (€99.90 @ Amazon Netherlands)
Memory: G.Skill Ripjaws V 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  (€75.90 @ Amazon Netherlands)
Video Card: PNY VERTO GeForce RTX 3050 8GB 8 GB Video Card  (€289.00 @ Amazon Netherlands)
Case: Deepcool MATREXX 55 MESH ATX Mid Tower Case  (€49.99 @ Amazon Netherlands)
Total: €994.41
Generated by PCPartPicker 2023-04-02 11:41 CEST+0200
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
