Hello there! I am new to Cisco FlexConnect (Officeextend) and i am wondering how it works. If i configure flexconnect, does the access point outside LAN create a VPN tunnel to my LAN or does it just brodcast the ssid's and do SSID to VLAN mapping?
Will it also work with mobility express? Can i use mobility express as an officeextend controller?
Thanks 🙂
https://linustechtips.com/topic/1497637-flex-connect-and-mobility-express/
