Since you helping someone.
Please next time add the things you've already tried. (As there is nothing more infuriating when trying to help to get to hear i've tried that already.)
Also let's start with the basics.
  1. Run anti-virus check
  2. Stop overclocking
  3. Update your drivers (starting with GPU)
  4. Update Windows
  5. Run disk check
  6. Run Memory check
If thats not enough, try using just 1 RAM-stick. (maybe even swap them out to rule out memory errors)
Report back.
Goodluck.
When i ask for more specs, don't expect me to know the answer!
I'm just helping YOU to help YOURSELF!
(The more info you give the easier it is for others to help you out!)
Not willing to capitulate to the ignorance of the masses!
  4. Update Windows
  5. Run disk check
  6. Run Memory check
Report back.
Goodluck.
Everything has now been attempted. It is still giving that error. Any other suggestions?
