Currently have 3700x - worth it to overclock, or should I plan for replacement?
System:
CPU: AMD Ryzen 7 3700X 3.6 GHz
Mobo: Asus ROG Strix X570-E
Memory: Corsair Vengeance RGB Pro 32 GB (2 x 16 GB) DDR4-3200 x2 (64GB total)
Storage: Samsung 970 Evo Plus 1 TB M.2-2280 NVME
GPU: EVGA 3080 Ti Hydro Copper
PSU: Corsair RMx 1,000 Watt
PC is water cooled.
I've recently updated the GPU and PSU. Mostly playing World of Warcraft, which I know is CPU heavy, and not getting the FPS I'd like. Is it worth it to try and squeeze more out of the CPU, or should I start planning for a platform upgrade?
5800x3D easy drop in replacement and the cheapest option for upgrade.
OC it (3700x)see if it makes enough of a diffrence for you.
Edited by Ottoman420
Is there a recommended guide or place to start for overclocking?
Same here, I got a 4080 but some games are similar if not the same in FPS (Mostly old games).
As Ottoman said, 5800x3d is now "cheap" and you can easyly upgrade without the need for MOBO or RAM.
3700x PBO stock | b550-f | Crucial Ballistix 8x4 32GB 3200MHz | RTX 4080 Asus TUF OC | SN 850 1TB - Crucial P2 1TB | Cooler Master XG 850w PSU
Yea it's not a dumb idea at all - looks to be about a 20% bump at stock.
Plus the extra cache will be a big plus when gaming.
Have you tried turning it off and on again? Maybe Restart it?
If my comment solves your problem mark it so.
Take everything I say with a grain of salt. I could be just about wrong as I am right.
Main RIG
13600K (Undervolted) +MSI Z690 Edge Wi-Fi+ Team Elite 32gb RAM (3200) +Noctua Nhd-15 Chromax Black+ Intel 670p 1TB SSD+ Intel Arc A770+ Corsair Crystal 465x case+ EVGA SuperNOVA 650W PSU.+ ASUS VP222 Gaming Monitor
Laptop for School: Surface go 2 (sucks ass)
Laptop for tinkering: Dell Inspirion 3358
Audio: Apple Airpods Pro (1st Gen)
(Apple_reigns_ supreme_ forever_ and_ ever)
(I am 14 years old and don't know shit about fucking shit.)
Everyone must suffer one of two Pains: The pain of Discipline or the pain of regret and disappointment.
-Jim Rohn
Dont forget to update bios and you are good to go.
Check out a link in this old thread about PBO it will take some playing around and i was looking for slightly less performance rather than more performance by lowering ppt and edc where the efficicncey is alot better but for almost the same performance. but you can use these tools for the opposite effect.
You're saying this in addition to the swap?
No thisis for using PBO to oc 3700x
For sure I will take a look, thank you! 🙂
