Hi, so i recently changed my motherboard and cpu and with the new setup ive been having onboard audio issues, other ear is only playing the audio and static noise on the other one.
i have not been able to find any fixes for this, i tried updating my bios but that did not do anything.
ryzen 9 3900X 1.25v 38x
asus tuf gaming b550 plus
https://linustechtips.com/topic/1497146-onboard-audio-issues/
this may be a problem with your headphones which are? Also what ports have you plugged in your jack?
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1497146-onboard-audio-issues/#findComment-15865859
Is this only on your front panel connector, or is it also happening on the motherboard's built-in audio connectors? If this is on your front panel, are you sure you have the correct connector plugged into the correct header, and that it's aligned the way it should be?
Do those headphones work properly on another known working device? Do other headphones work on that same connector on your PC, or do they have the same symptoms?
Are you sure your audio cable's plugged in all the way?
Are you running the latest audio drivers ASUS hosts for your new motherboard?
https://www.asus.com/motherboards-components/motherboards/tuf-gaming/tuf-gaming-b550-plus/helpdesk_download/?model2Name=TUF-GAMING-B550-PLUS
https://linustechtips.com/topic/1497146-onboard-audio-issues/#findComment-15865864
tripowin olina
i have them plugged in rear end io port (green one)
worth to note that the issue happens with other headphones aswell
https://linustechtips.com/topic/1497146-onboard-audio-issues/#findComment-15865869
motherboards built in audio connectors, and i tried installing that realtek driver and it did not help.
https://linustechtips.com/topic/1497146-onboard-audio-issues/#findComment-15865874
Plug the headphones in the other audio jacks ... modern sound cards have auto detection and will detect you plugged headphones.
The green jack in theory has better quality (lower noise floor, higher amplification if the motherboard has an extra headphone amplifier chip) but it would still be good enough with the other jacks.
If they work the same in other jacks, it's probably a fault in the motherboard. If it works fine, probably bad audio jack or maybe that optional headphone amplifier or whatever the motherboard has may be bad.
I wouldn't rule out completely the software (operating system, driver, could cause such issue but very unlikely)
https://linustechtips.com/topic/1497146-onboard-audio-issues/#findComment-15865915
24 minutes ago, keijo0 said:
The only way i can get proper audio working with my setup at the moment is using bluetooth headphones.
Have you tried any other headphones/iems or speakers connected to the same PC same audio port?
It might be the PSU or even the power (wall) socket.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/1497146-onboard-audio-issues/#findComment-15865918
Yes and the same thing happens on all of the headphones.
its outputting static noise as soon as the headphones get connected to the jack no matter if any audio is playing, if i play audio/vidoe the noise becomes more frequent and louder
https://linustechtips.com/topic/1497146-onboard-audio-issues/#findComment-15865928
none of other the jacks in the rear io output anything, i may be missing something here however
edit: there is static noise in 1 other jack in the rear io also.
i have tried installing all the software on the motherboard page for windows and no help there.
the same audio issues persist on linux.
https://linustechtips.com/topic/1497146-onboard-audio-issues/#findComment-15865937
Once you plug the headphones in another jack, you can go in the software that comes with the sound card  or somewhere in control panel , sound settings and specify the role of that audio jack
On my computer, I open the Realtek application by typing "realtek audio console" in the search box , because I don't remember the menu location and can't be bothered... it looks like this
If I click on Device Advanced settings, I get this ... so I can go on the green jack and select something else. Same for the orange and gray (I have a 5.1 speaker system)
You have an Asus motherboard - they like to rebrand the realtek audio chips as S1200 or S1220, so the application may be called something else, not "realtek audio console"
https://linustechtips.com/topic/1497146-onboard-audio-issues/#findComment-15865958
Is that with the volume on 100% in Windows?
Do you have a USB-C to 3.5mm active adapter to try with, maybe a DAC/AMP?
Can you try the PC on a different wall outlet with a different power strip?
https://linustechtips.com/topic/1497146-onboard-audio-issues/#findComment-15865979
0-100% doesnt change the loudness of the static noise
i may have some usb adapter somewhere
not easily doable.
 i recorded a short maybe confusing video but i found out something that i think may be abnormal but u guys are the experts
audio important
https://linustechtips.com/topic/1497146-onboard-audio-issues/#findComment-15865986
not easily doable.
audio important
I believe it might be voltage on the ground pin in the wall socket or a faulty power strip.
Voltage on GND would travel through the PSU to the board and from there to everything that uses the GND.
https://linustechtips.com/topic/1497146-onboard-audio-issues/#findComment-15866011
I found out that as soon as i start a display server on linux (wayland on xorg) the noise appears again but it doesnt do that in the tty.
odd behavior.
^^ i haven't had issues with this power strip before and i did try another one, powerstrip and wall outlet. Those did not help.
https://linustechtips.com/topic/1497146-onboard-audio-issues/#findComment-15866058
