Power Supply
Go to solution Solved by Spotty,
Are you having trouble with the cables that plug in to the power supply side or the computer side?
The RM850x and RM850e use the same type of cables. Guides for the RMx should apply to the RMe as well. The slots on the power supply are labelled with which cables go where.
Keep in mind if you are replacing another power supply you won't be able to use the old cables on the new power supply. You have to use the cables the power supply came with. Different brands/models can use different cables that aren't compatible.
Hi, I am very very new to all of this. My brother had put together my PC and just recently my power supply crashed. I had purchased a new one without looking into what I was getting and now I don't know exactly how to hook it back up and if it'll work. I purchased a corsair 850e, I tried using Google but I only see pictures and videos for the corsair 850x.. I'm sure it works I just need to figure out where to plug it in the slots.
https://linustechtips.com/topic/1495714-power-supply/
https://linustechtips.com/topic/1495714-power-supply/#findComment-15853638
It can cause permanent damage to PC parts 😄
https://linustechtips.com/topic/1495714-power-supply/#findComment-15853688
check the connectors on your motherboard 24 pin, eps power connector, any sata drives you have and any pcie power connectors for your gpu
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1495714-power-supply/#findComment-15853751
Okay makes sense now. So my power supply went out (the Corsair 750x) so I decided to get another one to replace it and ordered the Corsair 850e both fully modular. I thought it wouldn't matter so I decided to keep the cables and see about plugging them into the new power supply but the labels were different so I plugged them into the wrong slots. I tried looking up a YouTube video or whatever to hook it up properly, couldn't find one for the power supply I got.
https://linustechtips.com/topic/1495714-power-supply/#findComment-15863693
Would I be able to use the same cables from my last power supply? Last one was Corsair 750x, new one is Corsair 850e. I'm only asking because I tried disconnecting the old cables but some were really stuck to the motherboard and I don't wanna break it.
https://linustechtips.com/topic/1495714-power-supply/#findComment-15863696
Okay so.. I don't think the power supply is the problem anymore. I boot it up and it keeps going to the msi click bios 5 mode... I've tried many different methods on YouTube but nothing seems to be working. I don't think it's reading the proper hardrive that I downloaded windows on but idk how to do that exactly
https://linustechtips.com/topic/1495714-power-supply/#findComment-15863779
if you do this and use the same power cables from a different psu then you'll break all of your components
Total: £1040.95
https://linustechtips.com/topic/1495714-power-supply/#findComment-15863845
