Budget (including currency): >$2000
Country: USA
Games, programs or workloads that it will be used for: personal use and moderate gaming
Have an pc setup now but it is a prebuilt. Want to try building myself and looking for advice. Attached PCPartPicker build link. Do the parts look like they will work properly together? Found what looked interesting on PCPP and compiled the build, mainly centered around the RTX 3060. Any recommendations on alternatives for the build? Thank you all.
https://pcpartpicker.com/user/choccywafer/saved/nfkfpg
EDIT to include ssd:
https://pcpartpicker.com/list/Gv2CTn
Edited by choccywafer
Added updated PCPP list
https://linustechtips.com/topic/1495567-first-build/
Just now, choccywafer said:
The list is private.
It would also help to know what you're currently running.
A 3060 in a system that costs $2000 is not going to be a good value.
https://linustechtips.com/topic/1495567-first-build/#findComment-15852813
Country: USA
If $2000 excludes a new monitor, then you can easily fit a high end GPU into it, something like an RTX 4070ti (cringe) or 7900 XT.
Builder/Enthusiast/Overclocker since 2012 with a focus on SFF/ITX since 2014.
https://linustechtips.com/topic/1495567-first-build/#findComment-15852819
11 minutes ago, choccywafer said:
Should be public now
https://pcpartpicker.com/list/6tZm9r
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1495567-first-build/#findComment-15852936
Public now
current pc:
mag b365m mortar board
i3-8100
2x8gb ram
1050ti card
plan to give prebuilt to my fiancée
https://linustechtips.com/topic/1495567-first-build/#findComment-15852940
2 hours ago, choccywafer said:
Public now
current pc:
i3-8100
2x8gb ram
1050ti card
You can do a lot better than that list.
https://pcpartpicker.com/list/HbThfv
Everything in that list is faster, and it's still under budget. I'm assuming you're reusing your old SSDs or did you just forget to include them in the list?
https://linustechtips.com/topic/1495567-first-build/#findComment-15853116
Was driving when I was thinking of what was in my prebuilt. I installed a seagate drive and a Corsair nvme p.2 1tb ssd. May take the seagate but looking at a WD SN550 1tb ssd Will add to list. The list filpo made had an alternate ssd
https://linustechtips.com/topic/1495567-first-build/#findComment-15853129
