So I think with running a CPU and 2 GPU blocks, I should run 480MM of radiators.  How is this?  I Would intake in the bottom 120MM but I agree with my dad that we don't want hot air going into the case and I am gonna use SP120 silent fans so It won't move a TON of air.
Here is the part list:
http://pcpartpicker.com/p/WVer
Specs: Core I7-2600K @ 4.5GHz @ 1.35V, 4x4GB Corsair Vengeance Black 1600MHz CL9, Cooler Master Evo 212, MSI Z77 Mpower Motherboard, Sapphire Radeon HD 7950 Vapor-X @ 1000/1400, Cooler Master HAF 932 Blue Edition w/ 3 Cougar Hydraulic Bearing 120MM fans (2 up top 1 in the bottom) replaced side panel with a window, and rear fan with a Cougar Hydraulic Bearing 140MM, Cooler Master GX 650 80+ Bronze PSU, Samsung DVD-RW, Samsung 840 Pro 128GB SSD, Seagate 750GB SATA III 7200RPM
https://linustechtips.com/topic/14954-so-question-about-water-cooling/
1 pump will easily be enough. Use a Laing D5 or DDC 18W pump and it will be fine. Many people underestimate the power of these pumps.
Feel free to PM for any water-cooling questions. Check out my profile for more ways to contact me.
Add me to your circles on Google+ here or you can follow me on twitter @deadfire19.
I will be using the XSPC combo kit.  Here: http://www.frozencpu.com/products/16891/ex-wat-219/XSPC_Raystorm_750_RS240_Extreme_Universal_CPU_Water_Cooling_Kit_New_Rev_4_Pump_Included_w_Free_Dead-Water.html?tl=g30#blank
I will add a 120MM rad as well.  I can't seem to find the specs on this pump.
Do not buy kits. There are various reasons for this. I should start off by saying there is nothing bad with a kit. It will work properly and would will have a loop by the end of it. However, in kits the parts you get are typically low-end. I would never recommend a non-laing pump for a loop. Laing pumps are known for being quiet and reliable working for years without any issues. This is just an example. Kits tend to have lower quality everything. Secondly when buying a kit you will not be able to prioritise what you want in a loop. Maybe you are focusing on performance, maybe on looks? A kit will not give you this choice.
Most importantly a kit will not let you learn. Believe me when I say water cooling is a big investment, not only of money but also of time. If you feel that taking your time to look up components and make a parts list and doing research is something you would rather not do then you will be in for a shock later on. If you ever have a problem with your loop you will be much better placed after you have done your research and after selecting your own parts.
Therefore I advise you to go to the two stickys HERE and HERE and spend time reading about watercooling, then make a parts list and draw a diagram of what your loop is going to be, then ask us to review your parts and let you know what we think of the parts you have chosen.
I've read those but I went back again.  How do you feel about the swiftech pump/block combo? Could it power say 2 GPU blocks with 2 radiators? Res>block/pump>120MM Rad>Gpu1/2>240MM rad>bay res.
http://pcpartpicker.com/p/WoI3
So something like this?  I am using my HAF 932, but will replace the fans.  I already have 2x4GB of Ram getting 8gb more, and I have a 128GB Samsung 840 pro, just need a 256GB for storage for games.
pcpartpicker is not ideal for looks. I always ask people to get a 2d side on shot of their case and use paint to draw in their loop.
An example: http://imgur.com/MynbfCp
Also just bullet point your components. This makes it easy for me or someone else to reply and assist you. ;)
Oh I manually found everything and threw it together on pcpartpicker.  Mostly everything I added manually.  I have a HAF 932 case:
Res at the very top 5.25 bay.  Run down to the CPU/block, then to the 120MM rad where the exhaust is, down to the 2 GPU's, up to the 240MM radiator up top, then back over to the res.  Res will be several inches higher than the pump in elevation.
Sadly I do not have a catalogue of side shots of every case in my head. :(
An illustration would take you two mins. And because your water-cooling parts are mixed in with your normal parts its hard to help you. Bullet point list is much cleaner.
I have no way of uploading it here tho is the issue.
Herepost-16787-0-81860200-1368227740_thumb.p
Your first issue is I think you want to: waterblock -> rad -> waterblock -> rad There is no need to do this. Go for shorter runs where you can. Believe me when I tell you it makes no difference.
But doesn't it NEED to go res>pump? Well if pump is in the CPU block won't I want to go there first?
It does. I didn't notice you were using a CPU block and pump combo. My advise is don't. Just get a standard laing pump and a standard block. It will work much better.
I am trying to remove more points of failure and stuff.. ughhh...
Send me a link of a pump and a block that is 3/8 and 5/8 compatible for 150 or less.
Using a combo does not remove a point of failure. It just makes it harder to diagnose failures. You can try to find a pump and block for $150. Grab a Laing DDC pump and find a waterblock you like. You can also get a res and pump combo because they are actually good.
Get a laing pump. If you want good reliability laing pumps are the way to go. If you cheap out on a pump and it fails you could damage every component cooled by your loop.
None of the pumps I look at give me ANY description of what they are.  Can you find me a laing pump/res combo?
What reasonably priced pump would you recommend?
Only I only recommend Laing pumps because they are so reliable, quiet and powerful. So if you don't think a Laing pump is reasonably priced I don't know.
Use what linus uses, the swiftech mcp655
http://www.frozencpu.com/products/6190/ex-pmp-54/Swiftech_MCP655_12v_Water_Pump_w_Speed_Control_and_38_Conversion_Kit_317_GPH.html
Just turn it all the way down and it is completely quiet and powerful. I use it myself and the only downside I would say there is to it is that it's pretty big. Just make sure you get the one I linked and not the mcp655-b which does not have adjustable speed.
2500k @ 4.8, R9 290x, 256GB Vertex 4, Filco Majestouch 2 Tenkeyless Brown, Logitech G602 Mouse, Kingwin Lazer 1000w Platinum PSU, Corsair Dominator Platinum RAM 8GB @1866, Asrock Extreme 3 Gen 3, Xonar U7, Sennheiser 598, Switch 810, Coolermaster Hyper 212 with 1x Noctua nf-f12
Thats a Laing pump. ;)
