Whichever you choose it is a good idea to sync important data to a 3rd location. I have about 5TB of data on a 36TB volume but only 1.6TB is important enough to sync elsewhere (combination of Onedrive and a 5TB business google account).
AMD 7950x3D / Gigabyte Aurous Master X670E/ 64GB @ 6000c30 / 3 x 4TB Samsung 990 Pro / 44TB Synology 1522+ / MSI Gaming Trio 4090 / EVGA G6 1000w /Thermaltake View71 / LG C1 48in OLED + MSI 321URX - Moved back to air cooling Phantom Spirit 120 SE.  Server (PLEX) - 155H NUC 64GB  and 60GB Optane drive/ Server (AI) 64GB M4 Max Mac Studio
On 3/20/2023 at 2:24 AM, DragonMaster141 said:
Hi
I need a backup solution for 3 windows pc's and 2 phones.
I'm considering either going with a DYI Unraid server or a Synology NAS.
What would be the best option for this use case?
on unraid I use urbackup to backup indiviual computers around my house to the unraid server. I then have a crashplan subscription for 1 device that I use to backup the urbackup files to the cloud.
this gets you:
local files on device
backed up to second device locally (fast recovery)
backed up to cloud (robust, but slow to recover)
which satisfies bare minimum of 3-2-1.
the crashplan sub is $10 + the cost of my server.
If your question is answered, mark it so.  | It's probably just coil whine, and it is probably just fine |   LTT Movie Club!
Read the docs. If they don't exist, write them. | Professional Thread Derailer
Desktop: i7-8700K, RTX 2080, 16G 3200Mhz, EndeavourOS(host), win10 (VFIO), Fedora(VFIO)
Server: ryzen 9 5900x, GTX 970, 64G 3200Mhz, Unraid.
this gets you:
I fully agree with you, but I would recommend looking into different cloud services, to find one that fits your needs, and that you trust.
Main "Rig"=HP 11A G6 EE
Android Tablet
Raspberry PI Zero W 2
If you have any fun ideas for things for me to do with my PI, send me a direct message.
I plan to upgrade within a few months to a proper computer.
can you say why you you don't seem to like crashplan? or did you just mean in a general way to research different options
In general to find other options. I have no experience with much software, but I do know that you should do your research and not just take someones word for it
Android Tablet
