Temperature readings on processor bounces around going up to 40 degrees plus then eventually hovers around the 18 - 22 degrees, all this is in idol state no gaming or activity other than watching videos, is there a problem with my processor I don't want to strip it down if I can help it. Occasionally I will get a red led light on mobo indicating the cpu which stays lit after Windows has booted.  I7 12th gen cpu if that helps at all.  Gigabyte elite as mobo.   Why does it happen is it malfunctioning?
https://linustechtips.com/topic/1495042-zebedee-temps/
try reseating your CPU. This is what fixed the problem I had like this a few days ago but this won't help the high temps in idle. That has to do with the background tasks being loaded such as steam, teams, discord, spotify and rgb monitors such as icue. Can't do much to change that unless you disable some of them for startup (the ones you dont need)
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1495042-zebedee-temps/#findComment-15849249
