We need more information to help you. What game(s) are you talking about? What are your (and your friends) specs and game settings? Does he have a lower resolution/refresh rate monitor then you? Has he done any overclocking to any of his parts? Once we have this info we can help you better.
Keep in mind that I am sometimes wrong, so please correct me if you believe this is the case!
"The Nvidia Geforce RTX 3050 is brutally underrated"
https://linustechtips.com/topic/1495007-pc-help/#findComment-15848988
53 minutes ago, Monkerspc said:
my friend with lower specs then me gets way more fps on same settings in all games
He may be running a lower resolution which kinda counteracts some gpu holdback. Wild guess cause there is no context
I try to be a human, but I cannot, because I have returned to monke.
Hehe boi
POV- when it can run crysis-
 ( ͝° ͜ʖ͡°)
https://linustechtips.com/topic/1495007-pc-help/#findComment-15848989
2 minutes ago, Monkerspc said:
its not just a today problem noticed it for months
Well there are many things you could try. You could check functionality of all parts, clean the pc, OC, improve cooling, upgrade. So many options. Also if you're on windows 11 it can hinder performance sometimes.
https://linustechtips.com/topic/1495007-pc-help/#findComment-15849005
oh yah hes 10 I'm 11 I did the upgrade for les background tasks I doubt it tho cuz its in every game
https://linustechtips.com/topic/1495007-pc-help/#findComment-15849007
well there are many variables to take into consideration. He could take better care of his computer than you, you could have a damaged component, could be some stealthy malware, so many things it could be. As long as you're getting enough frames to match your monitors refresh rate, it shouldn't matter too much.
https://linustechtips.com/topic/1495007-pc-help/#findComment-15849606
