I wanted to look a bit into VR, but due to lack of time i dont want to spend to much on it, so i thought "why not go used?".
But the problem remains that i dont know much of anything about VR, so i turning to you. Which "older" headset makes sense?
My budget would be around 500 euro (i am a bit flexible there, but i still dont want to spend to much extra) and i just want to try some games like half life alyx or maybe also beat sabre etc. ...
just to note, i am short sighted but i dont know if that makes a difference for vr....
https://linustechtips.com/topic/1494850-good-used-vr-gear/
unless you're already deep up Mark Zuck's bumhole  I'd steer clear of Oculus/Meta stuff.  I looked at your profile you got quite a beefy rig.  You could go tethered to start.  You can pick up the OG HTC Vive for about half of what your budget is.  Then also that way you're on your way to building a better setup (like with the Index) cause all the parts all work with one another.
 With all the Trolls, Try Hards, Noobs and Weirdos around here you'd think i'd find SOMEWHERE to fit in!
https://linustechtips.com/topic/1494850-good-used-vr-gear/#findComment-15848028
Id rather stay away from zucks bumhole as far as i can... #
Soulds like a good idea, ill look out for good offers on ebay
https://linustechtips.com/topic/1494850-good-used-vr-gear/#findComment-15848038
10 minutes ago, Needfuldoer said:
I'm still happy with my first-gen HTC Vive. 🤷‍♂️
Yeah same man.  I used to have the Oculus but gave that to my girlfriend (cause she's already got Facebook) and got a second hand Vive for basically peanuts.  It's a great headset
https://linustechtips.com/topic/1494850-good-used-vr-gear/#findComment-15848047
Agreed. First gen vive should be cheap and give you an upgrade path as the controllers and lighthouses should work with newer vive headsets as well as Index and Pimax/other Lighthouse based headsets.
https://linustechtips.com/topic/1494850-good-used-vr-gear/#findComment-15850883
5 hours ago, _Omega_ said:
Already ordered a used full kit for 260 on ebay 😅
You won't be disappointed man.  You could even go wireless with the headset and still be under your original 500 euro budget
https://linustechtips.com/topic/1494850-good-used-vr-gear/#findComment-15851519
