I installed my Arctic Freezer 34 eSports DUO on Ryzen 5 5600x with B550 Gaming X V2, I never before installed aftermarket cooler on CPU and first time I installed it standoffs didn't really go all the way in, one or two were always allot higher, i tested it like that temps don't go over 65 C and idle over 35C, I refited it few minutes ago, all the standoffs went in almost exactly, played with them a little bit, they are not all the way in exact 1-2mm delta. It fits good as far as I can see, no sounds when putting it on, backplate has no wiggle room.
Pictures below:
Is that all ok, it seems just fine with the temps, I run tests all day, it just won't go over 65, did I fit that cooler good enough?336506386_130359506472870_8576835958477698601_n.thumb.jpg.27b19ab010eb84d3df97c31f7fb618f3.jpgIMG_6265.thumb.png.a2755880af9eed8b7e6253398b6aac51.png
Ryzen 5 5600x | XFX MERC RX 7900 GRE  | 2x16GB 3200MHz | Samsung 980 1TB | 1 TB WD Blue | 120GB A400 Kingston Gigabyte M2 NVME 512GB  | BeQuite Straight Power11 80+ Gold 750W
https://linustechtips.com/topic/1494495-tower-cooler-question/
That is very good temperatures, better than my 5600 on a NH-D9L (u12s doesnt fit). Certainly have lots of room to turn on Precision Boost Overdrive or do some manual overclocking (although PBO . My only concern is that cooler looks like its resting on the graphics card beneath. If it is, at least put some electrical tape between the two so they cant short anything out.
https://linustechtips.com/topic/1494495-tower-cooler-question/#findComment-15845517
I made sure they will fit nicely, no touchy touchy
https://linustechtips.com/topic/1494495-tower-cooler-question/#findComment-15845531
