so i just built my first pc
b450m steel legend matx
ryzen 5 2600x
32 gb ddr4 @ 33600 mhz
gigabyte 5700xt oc
deepcool aio
fractal pop mini air white rgb
samsung g5 1440p 165 hrz monitor
xbox series s
thermal grizzly applied on both cpu and gpu
problem im having is above average temps on both gpu and cpu  hovering in the 80 deg range while play games like dragon age and older titles aswell as newer ones
and i cant figure out why
https://linustechtips.com/topic/1494376-my-first-pc-build/
4 minutes ago, ODi187 said:
Budget (including currency): 600 canadian rupes
Country: canda
Games, programs or workloads that it will be used for:
ryzen 5 2600x
gigabyte 5700xt oc
deepcool aio
xbox series s
is both the gpu and cpu hitting 80c?  If its the CPU then you might need to adjust the pump speed to faster flow of water and maybe the fan speed as well.  What orientation is your fan setup?
https://linustechtips.com/topic/1494376-my-first-pc-build/#findComment-15844649
the fan speed is set high adn the pump speed aswell. the fan orientation is push pull.
front is pulling air and the aio and back fan are exhaust
https://linustechtips.com/topic/1494376-my-first-pc-build/#findComment-15844653
-Thread moved to Troubleshooting-
https://linustechtips.com/topic/1494376-my-first-pc-build/#findComment-15844679
80c is still within safe limits for both the CPU and GPU,  what are you using to get the readings?  I know the gigabyte 5700xt oc is a hot card and the hotstop temperature can reach upwards of 90-100c / still safe.  ( 110c being max )
https://linustechtips.com/topic/1494376-my-first-pc-build/#findComment-15844680
msi afterburner. but im playing mostly older titles and some not exactly AAA titles
im just replaying all the games i used to play on my xbox lol
https://linustechtips.com/topic/1494376-my-first-pc-build/#findComment-15844716
Is your PSU positioned to draw air from under the case, or through the vented area underneath your GPU? I figure you have it drawing air from underneath, but I’ve seen people flip it and pull air from inside the case.
It wouldn’t help your GPU at all, but if you install the AIO radiator in the front, you could drop the CPU temp a few degrees. Also, is the AIO pump connected to a chassis fan header or the pump header? If it’s connected to the pump header it should run at 100% all the time (unless changed in the bios)
https://linustechtips.com/topic/1494376-my-first-pc-build/#findComment-15844718
no the only way to get air flow to the psu is bottom mount drawing air from under the case its a 750w
and thanks spent months researching the specs i needed. i love my build and the rgb lol. i change the rgb depending on if the leafs packers or the irish are playing. if none are playing the build goes all green
https://linustechtips.com/topic/1494376-my-first-pc-build/#findComment-15844764
The problem with the h510 case is that the air gets stuck under the gpu because you have a long card in a short case. This ltt vid has a better explanation at around 4:30
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1494376-my-first-pc-build/#findComment-15844913
3 hours ago, ODi187 said:
I have a fractal pop mini air
oh shoot sorry that looked like the h510 but sitll theres not enough space for the gpu to have that air
Total: £1040.95
https://linustechtips.com/topic/1494376-my-first-pc-build/#findComment-15845532
