Dell Fan Control
Solved by dragonhart6505,
9 minutes ago, AinzOoalGownSama said:Intel(R) Core(TM) i5-6440HQ CPU @ 2.60GHz 2.60 GHz
yeah...ok...you're system will do absolutely fine with that pad and its software lmfao. last comment had me about to change my remedy to throwing it back at your e-waste friend. definitely give it a fresh coat of paste, i'm not sure how long you've had it or if your friend had already had that taken care of but if heat is the issue definitely take care of that first. good ol' kryonaut would probably be overkill, but Best Buy has some very decent Corsair TM30 that is only a few bucks for a tube that would go well across half a dozen systems use if you want a quick pick-up. loved the stuff on my Lenovo Legion 5 with a toasty running Ryzen 5 4600H
