So I want to use the Lian Li Uni SL-Infinity Fans as I love the look of them but I can't find any AIO's made by them that use these fans. Could I buy any AIO from any brand and replace the fans?
If yes can fanless AIO's that are cheaper than AIO's that come with fans? Or do I have to sell the fans that come with it?
https://linustechtips.com/topic/1494328-can-i-replace-aio-fans/
yes ofc you can do this you just need the correct screws from that aio, but those should come with the aio and make sure your lian li fans are standard width (25mm)
A standalone aio is pretty unusual but yes you will probably have to sell the fans or you could keep using them in your case. How big would your aio be?
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1494328-can-i-replace-aio-fans/#findComment-15844311
Thank you for your answer. The AIO will be 360mm.
https://linustechtips.com/topic/1494328-can-i-replace-aio-fans/#findComment-15844372
