Hi Everyone,
I am searching for some help. I have had this computer I built for a while, I upgraded to a 3070 and had similar issues with my 1080 and I can't seem to figure out why my FPS is so low or will fluctuate so much. I have installed new drivers, reset windows. Restarted computer. I benched my cpu with z-cpu scored a bit low 2485.2 compared to reference 2648, but that shouldn't be this massive of a difference. My temps all seem to be normal.
PC Specs:
CPUi7-7700k cooled with noctua dh15s
ram: 16gb at 2133
GPU: rtx 3070- evga xc3
SSD
The games I play mostly are Smite and Valorant.
Smite is the biggest problem I run on flucuate on medium or low settings from around 90-144fps so much tearing it is hard to play sometimes
Valorant on Low settings gets me 165. FPS estimator says I should be getting 367 on high.
Please let me know if you have any thoughts or solutions.
I started on medical leave and aren't really in a spot to financially to replace CPU and mother board and ram.
https://linustechtips.com/topic/1494085-low-fps-and-fluctuation-issues/
4 minutes ago, bredtoshred said:
Hi Everyone,
PC Specs:
ram: 16gb at 2133
SSD
it could be a slight CPU bottleneck, its starting to show age ( 6 years )  and a 4 core CPU do struggle in 2023. However, I would think that Smite and Valorant are somewhat easy games to run.
I had the same problem with 1080 I don't think its a bottleneck especially given the low graphics setting which would be gpu?
The lower the graphics settings and resolution you run the more it stresses the CPU not the GPU. If you want the GPU to be the workhorse run the game in higher resolutions and higher settings to take more of the load off of the CPU.
A 3070 will absolutely bottleneck a 7700k.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
so I raised the settings to high a, I only have a 1080p monitor so I left it, but I havent gone over 120 fps
That's going to be due to your 7700K, you definitely have a CPU bottleneck.
6 hours ago, bredtoshred said:
But like when I had 7700k and gtx 1080, I would have similar problems. CPU still bottlenecking 1080?
If you played on low details with that generations old i3 (don't tell me it's an i7, the 7700K has the same technology, same number of cores, same number of threads and similar clocks to an i3 10100!) you were severely bottlenecking even the 1080 card.
What you got from upgrading to a stronger card while keeping the details is even more stutters since the new card is bottlenecked a lot more than the old. And the 3070 probably switches between lower power profiles (since the CPU can't feed it) so that's even worse.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
