Is Alex Legends capped to 144 fps normally because when I play Apex it caps out at 144 fps with no external riva tuner cap and j was wondering if I can unlock it
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1493557-apex-frame-rate-cap/
By default vsync is on. Also make sure that your autoexec doesnt have "fps_max" argument on, and same applies to your launch options in EA play or Steam. Same with driver-side max framerate in Nvidia control panel or Adrenalin. Apex Legends player loved to cap their framerate for consistent frametime, as you need that for consistent movement tech trigger.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1493557-apex-frame-rate-cap/#findComment-15838892
Ok thank you I already had v sync off but didn’t know about the code in the game. Cheers
Total: £1040.95
https://linustechtips.com/topic/1493557-apex-frame-rate-cap/#findComment-15838922
