Hi there!
I have done quite a lot of planning and it would be nice to have some feedback on any improvements or suggestions for my build.
It would be used for Flight Simulation, which pushes GPU and Mostly CPU utilisation very high. PC would run for several hours at a time every day. I’m more concerned about performance than noise. Would be running at a room temp of ~21-24c
Case - MSI Gungnir 110R (I can’t change this, but I know about the bad airflow)
Motherboard - either ASUS ROG Strix Z690-E Gaming WiFi or MSI Z690 Carbon WiFi
CPU - i7-13700K (would like to OC a bit if AIO allows)
Cooler - DeepCool LS720 (360mm front mounted)
RAM - DDR5 32GB Kingston Fury Beast 5600 CL36
GPU - Possibly RTX 4070 (non-Ti)
Storage - 256GB M.2, 1TB SSD, 2TB HDD
PSU - 850W Gold
Thank you in advance for your responses and have a great day 🙂
https://linustechtips.com/topic/1493498-my-first-build-plan/
17 minutes ago, thomaswilk said:
I can’t change this
And why is that? You bought it already have you?
Id say you should consolidate the budget for this elaborate sets of storage to 2TB M.2 nvme SSD. Itll come out cheaper, and partitioning an SSD is a fine behavior if thats a concern.
Also as usual, budget and location of purchase would be very nice to know.
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1493498-my-first-build-plan/#findComment-15838510
5 hours ago, thomaswilk said:
Hi there!
PSU - 850W Gold
This build is without the GPU and I made a change or two with the storage and RAM but for the GPU I think you should go with a 3090 because flight simulator uses a lot of VRAM as seen in the pic below
https://pcpartpicker.com/list/q29478
So for this I would recommend getting a used 3090 because prices have gotten much better such as this one (btw shipping price is so high because I'm in Europe and these are in the US) -
Or this one
Message me on discord (bread8669) for more help
Quote me if you want me to get notified
Current parts listPCPartPicker Part List
CPU: AMD Ryzen 5 7600 3.8 GHz 6-Core Processor  (Purchased For £175.00)
CPU Cooler: Thermalright Phantom Spirit 120 SE ARGB 66.17 CFM CPU Cooler  (Purchased For £0.00)
Motherboard: MSI PRO B650M-A WIFI Micro ATX AM5 Motherboard  (Purchased For £144.99)
Memory: Corsair Vengeance 32 GB (2 x 16 GB) DDR5-6000 CL30 Memory  (Purchased For £89.99)
Storage: Crucial P5 Plus 500 GB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (Purchased For £0.00)
Storage: Kingston A400 960 GB 2.5" Solid State Drive  (Purchased For £0.00)
Video Card: Gigabyte GAMING OC Radeon RX 7800 XT 16 GB Video Card  (Purchased For £448.99)
Case: Lian Li LANCOOL 205M MESH MicroATX Mini Tower Case  (Purchased For £82.98)
Power Supply: MSI MAG A850GL PCIE5 850 W 80+ Gold Certified Fully Modular ATX Power Supply  (Purchased For £99.00)
Total: £1040.95
Damn this space can fit a 5090 (just kidding, it needs more)
https://linustechtips.com/topic/1493498-my-first-build-plan/#findComment-15838683
Or this one
Thank you for suggesting second have cards, not sure how I didn’t think of that.
https://linustechtips.com/topic/1493498-my-first-build-plan/#findComment-15839341
Ye don’t sweat it. I made some mistakes on my first build like picking a mobo with terrible power delivery
Total: £1040.95
https://linustechtips.com/topic/1493498-my-first-build-plan/#findComment-15839374
6 hours ago, thomaswilk said:
How can you tell if it has bad power delivery?
Check how many power phases it has, more is better, better chipsets are normally better for a higher end build on intel for overclocking but on AMD it's not necessary to get an X chipset since even B boards have the full feature set apart from maybe super high RAM speeds. Also don't go for super budget boards like this one. They normally look ok on the surface but in reality can't deliver (both in performance and power) I used a board like this with my 10100f and it couldn't break the 45W power to get to its 65W power target because of its power delivery and VRMs. If you want to learn more about motherboards and how their performance gets affected, its a bit old but theres an LTT vid linked down below
Total: £1040.95
https://linustechtips.com/topic/1493498-my-first-build-plan/#findComment-15839929
