The other day, I used Intel's Driver & Support Assistant to update the drivers for my laptop's Iris Xe GPU, Wi-Fi Adapter and Bluetooth Adapter. The problem child is the Bluetooth one, updated to 22.200.0.2. Since installing, my laptop has not been synchronizing properly with my Bluetooth earbuds. Tapping either to trigger play/pause or Skip/Rewind doesn't work, meaning I either have to open the Action Centre or the media app and trigger the respective function, and adjusting audio using the media keys on my keyboard doesn't work either, meaning I have to use the earbuds to adjust it. Audio still plays fine, and it is picked up as an audio device by Windows. This is my only pair of Bluetooth headphones, and the controls work fine while connected to my phone. The only variable that's changed is that driver update. Is it worth rolling back to see if it WAS this update that broke the functionality?
https://linustechtips.com/topic/1493483-wireless-bt-audio-problems/
