First time posting here, hopefully this how you do it. Basically I've put together my pc (i7 13700k, asus z790-a WiFi, rtx 3070, 1x32gb ram(bought 1x32 instead of 2x16, should still boot though), a wd blue m.2 and a gigabyte ud750gm), and after pushing the power button, the psu clicks once, aaand nothing. The rbg on the mobo works, incase that makes a difference. I've tried using different pcie/cpu holes on the psu, no difference. Even incase the mb was shorting with something in the case, I removed it, and it still clicked, and did nothing. I heavily doubt it's a motherboard failure, but im running out of options. Could it maybe be a short somewhere? I even popped out the cpu and all the pins look fine. I'm lost, I'm gonna take it to a repair shop, unless there is a easy fix to this.
https://linustechtips.com/topic/1493016-pc-does-nothing-after-pushing-power-button/
Try testing your PSU with the paperclip trick. Does it turn on ?
Refresh before you reply
Do you have all the front panel connectors wired up correctly?
Have you tried turning it off and on again? Maybe Restart it?
Please make sure to Mark the Solution as a Solution.
Take everything I say with a grain of salt. I could be just about wrong as I am right.
Main RIG
13600K (Undervolted) +MSI Z690 Edge Wi-Fi+ Team Elite 32gb RAM (3200) +Noctua Nhd-15 Chromax Black+ Intel 670p 1TB SSD+ EVGA FTW Nvidia RTX 3090+ Corsair Crystal 465x case+ EVGA SuperNOVA 650W PSU.+ ASUS VP222 Gaming Monitor
Laptop for School: Surface go 2 (sucks ass)
Laptop for tinkering: Dell Inspirion 3358
Audio: Apple Airpods Pro (1st Gen)
(Apple_reigns_ supreme_ forever_ and_ ever)
(I am 16 years old and don't know shit about fucking shit.)
Everyone must suffer one of two Pains: The pain of Discipline or the pain of regret and disappointment.
-Jim Rohn
I followed corsair's tutorial, the fan spun for half a second, and it made that click noise when I shorted the pins even when it was switched off..
1 hour ago, Shawn3 said:
What light comes up on the motherboard? Going by the manual, that board seems to have Q-LED which might point you in a particular direction
CPU=Red
DRAM=Yellow
VGA=White
Boot=Yellow green
I press the power switch and the psu just clicks, the light/s simply don't turn on
10 minutes ago, Shawn3 said:
Sounds like trying either a spare or a friends PSU if possible may be in order, to confirm if it's the issue.
I don't have friends with computers powerful enough to use 2 8pin cpu and 1 6pin and 1 8pin pcie connector, and the one friend who might have it lives in a different village. :/. I think pc shop is my only option tbf
