Hey y'all, I was looking over my system and realized I have an unpopulated front panel USB C header, but i don't have a case with front panel USB C. Are there any PCI slot cards out there that can take the header and put it out the back near the rear IO, so I can at least use that extra set of USB for something like a USB C hub? Motherboard is a B650M-A WIFI and the case is a Corsair 280X Crystal if that helps at all, as well as a GPU that takes up two slots. This is part of the reason I'm reluctant to use a typical PCIE-to-USB C card, so I don't choke out any airflow to the card from the PCB getting in the way.
https://linustechtips.com/topic/1492918-using-unpopulated-usb-c-headers/
https://www.amazon.com/GRAUGEAR-Extension-Profile-Bracket-G-AD-ETC-10G/dp/B09YRMQT1F/ref=sr_1_4?crid=2KRZFW8AI0O37&keywords=Type+E+to+usb+c&qid=1678352268&sprefix=type+e+to+usb+c%2Caps%2C315&sr=8-4
https://www.amazon.com/MZHOU-Extension-Internal-Adapter-Screw-57/dp/B083FRW542/ref=sr_1_3?crid=2KRZFW8AI0O37&keywords=Type+E+to+usb+c&qid=1678352268&sprefix=type+e+to+usb+c%2Caps%2C315&sr=8-3
There's also adapters that turns Type E to USB3 header if you ever need one for some reason.
Refresh before you reply
you're a life saver, thanks so much! literally had spent an hour searching with no dice before. i also now know the proper name for that type of header which is a bonus.
Haha ya, not many people know the header name.
I just use "Internal USB C header" back then.
Also, in case you don't know.
If you don't quote their post or tag their name (example : @JackTrade), most often peoples here won't notice that you replied to their post.
There should be a ton of options at Aliexpress, since the ones in Amazon practically mostly sold by companies in Aliexpress too.
