16 minutes ago, Xa3phod said:
I have a Micro ATX board which is 24.4cm x 21.5cm. The case I am looking at will accept 9.6” x 9.6” (Micro ATX).
9.6" = 24.384cm. That seems like a tight fit. Less than 1.5cm space.
Thanks
its a tight fit but if it fits it fits.. MicroATX cases usually operate under such tight dimensions.
https://linustechtips.com/topic/1492602-will-it-fit/#findComment-15832443
