For the past couple of years my rig has been inside a Cooler Master Haf X, and recently i have wanted to down size my case and were wondering if any one has any good suggestions for a decent small (perhaps cube) ATX case which is able to fit 120mm x 275mm x 27mm rad (h100i), AVerMedia Game Capture card (1 PCI-E slot!) and a H=43 mm, L=275 mm, W=136.6 mm GPU (Gigabyte 670)
Budget is <£70
Cheers in advance!
<a href="https://hashflare.io/r/311DC12A"><img src="https://cdn.hashflare.eu/banners/en/1280x628_1_eng.png" alt="HashFlare"></a>
https://linustechtips.com/topic/149229-suggestions-on-next-pc-case/
Specs
You should definitely check out Scan's list of Mid tower cases:
http://www.scan.co.uk/shop/computer-hardware/all/cases/performance-cases
The Phantom 240 looks pretty great, although you can customise it on NZXT's website if you wish.
The Zalman Z3 plus is also a great choice.
@SAV1OUR - Isn't it a bit too pricey? And Y U have to use PC Part Picker?
Edited by tomlambert01
Compatible with Windows 95
Was going to say 300R because I have one but then I remembered you can't fit a H100i in D: (But can fit H80/H80i)
Honestly I'm not sure, if you can find a case for £70 that can fit a h100i?
I'll edit it if I find anything
Case: Carbide 300R
CPU: i5 4690K @ 3.90GHz
RAM: 8GB DDR3
Mobo: MSI Z97-G45 Gaming
GPU: R9 290 Tri-X
PSU: EVGA SUPERNOVA NEX650G
Storage: 4TB NAS
Drive 1: Seagate 1TB 7200RPM
Drive 2: WD 500gb 7200RPM
___________________________
Keyboard: Vengeance K50
Headset: Vengeance 1500 V2
Mouse: R.A.T 5
Monitor: LG 24EN33
It shows the different prices and what retailers are selling it for whatever price.
Case: Carbide 300R
RAM: 8GB DDR3
GPU: R9 290 Tri-X
Storage: 4TB NAS
Mouse: R.A.T 5
Monitor: LG 24EN33
im sure he can stretch $9 and i linked it so he could see all the stores stocking it
Specs
Fractal Design Define R4, a h100i fits in this case with an Asus Sabertooth Z87 mainboard (Quite a thick board because of the Thermal Armour).
Social Links: LTT Forum    Website    Instagram    Twitter    YouTube    LinkedIn    Steam
The Build
CPU Intel i7 4770k 4.4ghz Motherboard Asus Sabertooth Z87 RAM 34gb (4 x 8gb) Corsair Vengeance 1600mhz GPU Evga GTX780 Classified Case Lian Li O11 Dynamic Storage Samsung 840 256gb SSD PSU Corsair HX750 Display Achieva Shimian QH300-IPSMS 1600p Cooling Corsair H100i Keyboard Corsair K90 Mouse Corsair M65 Sound 3.1 Surround Sound Fans 2x Corsair SP120 PWM, 3x Corsair AF140 Q.E, and 1x Corsair AF120 Q.E.
  • 2 weeks later...
Corsair Graphite 760T, corsair obsidian 750D or the nzxt h440 depending on budget
I Love Playing CS:GO!
Current
AMD Athlon X4 760K | MSI A78M-E45 | Sapphire R7 265 | Cougar Solution | Cooler Master Hyper T4 | ADATA XPg V1.0 1600Mhz 8GB | Fractal Design 650W
