HDR not working
Go to solution Solved by Andrewtst,
19 minutes ago, BARBOUSS said:
but it is advertised as it has hdr 400, anyways i figured out how to turn it on but it looks shitty on windows and gaming but when i go to see a video it turns iut to be great i even compared without it...is it some settings or is it for example a shitty cable because, i saw that only supports dp 1.4 or higher and im not sure if mine is at least 1.4
i m using the one that came with it
VESA DisplayHDR 400 never look good in HDR because it is way too low brightness to bring out HDR suppose look. VESA make a big mistake by certified HDR400 and make many buyer became victims.
if the video you see is those YouTube demo or very bright scenes, then it will look quite ok actually but actual HDR movies will look bad especailly on those dark scenes or night view.
HDR 600 is the minimum if you want to taste HDR, HDR 1000 is the requirement if you want fully enjoy HDR.
12 minutes ago, Brooksie359 said:
Yeah that is not an actual HDR monitor so even if you turn HDR on it won't do anything unfortunately.
https://linustechtips.com/topic/1492156-hdr-not-working/#findComment-15829359
PC: AMD Ryzen 9 5900X, Gigabyte GeForce RTX 4090 OC 24G, X570 AORUS Elite WIFI Motherboard, HyperX FURY 32GB DDR4-3200 RGB RAM, Creative Sound Blaster AE-9 Sound Card, Samsung 970 Evo Plus M.2 SATA 500GB, ADATA XPG SX8200 Pro M.2 SATA 2TB, Asus HyperX Fury RGB SSD 960GB, Seagate Barracuda 7200RPM 3.5 HDD 2TB, Cooler Master MASTERLIQUID ML240R ARGB, Cooler Master MASTERFAN MF120R ARGB, Cooler Master ELV8 Graphics Card Holder ARGB, Asus ROG Strix 1000G PSU, Lian Li LANCOOL II MESH RGB Case, Windows 11 Pro (22H2).
Laptop: Asus Vivobook "A Bathing Ape" - ASUS Vivobook S 15 OLED BAPE Edition: Intel i9-13900H, 16 GB RAM, 15.6" 2.8K 120hz OLED | Apple MacBook Pro 14" 2023: M2 Pro, 16 GB RAM, NVMe 512 GB | Asus VivoBook 15 OLED: Intel® Core™ i3-1125G4, Intel UHD, 8 GB RAM, Micron NVMe 512 GB | Illegear Z5 SKYLAKE: Intel Core i7-6700HQ, Nvidia Geforce GTX 970M, 16 GB RAM, ADATA SU800 M.2 SATA 512GB.
Monitor: Samsung Odyssey OLED G9 49" 5120x1440 240hz QD-OLED HDR, LG OLED Flex 42LX3QPSA 41.5" 3840x2160 bendable 120hz WOLED, LG UltraGear Gaming Monitor 34" 34GN850 3440x1440 144hz (160hz OC) NanoIPS HDR, LG Ultrawide Gaming Monitor 34" 34UC79G 2560x1080 144hz IPS SDR, LG 24MK600 24" 1920x1080 75hz Freesync IPS SDR, BenQ EW2440ZH 24" 1920x1080 75hz VA SDR.
Input Device: Asus ROG Azoth Wireless Mechanical KeyboardAsus ROG Chakram X Origin Wireless MouseLogitech G913 Lightspeed Wireless RGB Mechanical Gaming Keyboard, Logitech G502X Wireless Mouse, Logitech G903 Lightspeed HERO Wireless Gaming Mouse, Logitech Pro X, Logitech MX Keys, Logitech MX Master 3, XBOX Wireless Controller Covert Forces Edition, Corsair K70 RAPIDFIRE Mechanical Gaming Keyboard, Corsair Dark Core RGB Pro SE Wireless Gaming Mouse, Logitech MK850 Wireless Keyboard & Mouse Combos.
Entertainment: LG 55" C9 OLED HDR Smart UHD TV with AI ThinQ®, 65" Samsung AU7000 4K UHD Smart TV, SONOS Beam (Gen 2) Dolby Atmos Soundbar, SONOS Sub Mini, SONOS Era 100 x2, SONOS Era 300 Dolby Atmos, Logitech G560 2.1 USB & Bluetooth Speaker, Logitech Z625 2.1 THX Speaker, Edifier M1370BT 2.1 Bluetooth Speaker, LG SK9Y 5.1.2 channel Dolby Atmos, Hi-Res Audio SoundBar, SONOS ACE, Technics AZ80, Technics A800E, Sony MDR-Z1R, Bang & Olufsen Beoplay EX, Sony WF-1000XM5, Sony WH-1000XM5, Sony WH-1000XM4, Apple AirPods MAX, Apple AirPods Pro 2, Samsung Galaxy Buds2, Nvidia Shield TV Pro (2019 edition), Apple TV 4K (2017 & 2021 Edition), Chromecast with Google TV, Sony UBP-X700 UltraHD Blu-ray, Panasonic DMP-UB400 UltraHD Blu-ray.
Mobile, Tablet & Smart Watch: Google Pixel 9 Pro XL (Obsidian) Apple iPhone 15 Pro Max (Natural Titanium), Apple iPad Pro 11" 2024 M4 (Space Black), Apple Watch Series 8 Stainless Steel with Milanese Loop (Graphite).
Others Gadgets: Asus SBW-06D2X-U Blu-ray RW Drive, 70 TB Ext. HDD, j5create JVCU100 USB HD Webcam with 360° rotation, ZTE UONU F620, Maxis Fibre WiFi 6 Router, Fantech MPR800 Soft Cloth RGB Gaming Mousepad, Fantech Headset Headphone Stand AC3001S RGB Lighting Base Tower, Infiniteracer RGB Gaming Chair
https://linustechtips.com/topic/1492156-hdr-not-working/#findComment-15829369
thankss
https://linustechtips.com/topic/1492156-hdr-not-working/#findComment-15829397
Unfortunately HDR is often advertised when realistically they don't actually have the necessary components to make HDR work. First and foremost is you need local dimming in the forms of groups for ips displays as otherwise you won't actually be able to have one section of the screen bright while the other is dark as normal ips displays can't do that without multiple backligh groups. Oled can achieve this without needing for local groups so generally any decent oled display should support HDR content well. Anyways unless you see an ips panel that has local dimming with a decent amount of zones I wouldn't consider it as being an HDR display. Oled being excluded as the technology itself allows for high quality HDR.
https://linustechtips.com/topic/1492156-hdr-not-working/#findComment-15830043
