Budget (including currency): 1500 usd
Country: usa
Games, programs or workloads that it will be used for: fortnite, blender, minecraft,
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): this is where I'm at right now https://pcpartpicker.com/list/thCz3y I'm probably goin to buy a used gpu just because they are a bit cheaper.  I really dont need anything above 1080 p but 1440 would be nice. Also looking to save money but willing to buy new products.
Update:  I have a revised pc parts list
https://pcpartpicker.com/list/TsTmtn
thoughts?
Edited by habidtenly
https://linustechtips.com/topic/1492105-first-build-help/
If you want something at the actual budget, you can get something like this system:
https://pcpartpicker.com/list/vX6rk9
If you want something closer to the budget of the system you picked out, you could get something like this:
https://pcpartpicker.com/list/fm9rk9
Both of these will be a little faster than the system you picked out.
https://linustechtips.com/topic/1492105-first-build-help/#findComment-15828929
Hi,
I have provided a list of reccomended items. Ryzen is cheaper so that is what I reccomend you go with. Yes if you want to get a second hand GPU that is fine but if you don't then I have provided one. You also forgot about the PSU. You also do not have to get brand names for ssd and ram.
Here are the parts: https://pcpartpicker.com/list/
https://linustechtips.com/topic/1492105-first-build-help/#findComment-15828936
Noctua D15 is an overkill. If you like noctua, U12 or U9/D9 is enough for 12400.
Main Desktop:
Case:Jonsbo A4
CPU: Intel Core i9-12900K
GPU: Intel Arc A770 Limited Edition
CPU Cooling: Asus ROG Strix LC II 240mm AIO, with 4x Noctua A12x25 Fan.
Motherboard: Gigabyte Z690i Aorus Ultra DDR4
RAM: G.Skill DDR4 3600CL18 32GBx2
System Drive: Samsung 970Pro 1TB.
File Drive: Samsung 980Pro 2TB.
Media Drive: Intel S4510 3.84TBx2 (RAID 0)
PSU: Silverstone SX650G 650W SFX
Mini Home Server:
Case: Akasa Plato X8
CPU: Intel i5-8259U
Cooling: Passive Cooling Case
Motherboard: NUC8 i5BEH
RAM: 2400Mhz 16GBx2
Drive: Samsung 970Pro 512GB.
NAS :
Case: Jonsbo N1
CPU: Intel Xeon D-1521
Motherboard: X10SDV-4C-TLN2F
RAM: Micron 2400MHz ECC RDIMM 32GBx4
Pool 1: Data: WestDigit Red Plus 8TBx5 (RAID-Z1) Metadata: Intel P1600X 118GBx2 (Mirror)
Pool 2: Intel 670P 2TBx3 (RAID-Z1)
PSU: Silverstone SX300-B SFX
Mobile Devices: Microsoft Surface Laptop 4 (13.5-inch edition) | Microsoft Surface Go 2 | Samsung Galaxy Z Flip 4 | Samsung Galaxy Watch 5 | Microsoft Surface Headphones | Sony Linkbuds S | Sony Linkbuds
https://linustechtips.com/topic/1492105-first-build-help/#findComment-15828942
thanks! I found this in the compatibility notes :The Thermalright Peerless Assassin 120 SE WHITE ARGB 66.17 CFM CPU Cooler may require a separately available mounting adapter to fit the Gigabyte Z790 UD AC ATX LGA1700 Motherboard.
https://linustechtips.com/topic/1492105-first-build-help/#findComment-15828963
That's only if you get one that's been sitting on a shelf for 2 years. Realistically it's pretty rare that you'd need to get a mounting hardware kit for the cooler, and that Peerless Assassin 120 will outperform pretty much any other cooler you can find for $40.
https://linustechtips.com/topic/1492105-first-build-help/#findComment-15828964
I must say I find it amusing that my PC that I think is about $2500 USD uses a used version of the GPU that you recommend for a 1500 PC. Admitedly part of that is early adopter AM5 and having specific needs related to non-gaming stuff but still funny to see the asrock OC 6700XT.
https://linustechtips.com/topic/1492105-first-build-help/#findComment-15828971
ahhhh ok
https://linustechtips.com/topic/1492105-first-build-help/#findComment-15828976
as are the times my friend, as are the times
https://linustechtips.com/topic/1492105-first-build-help/#findComment-15828980
1 hour ago, StickyPC said:
Hi,
Thanks for letting me know! I probably would have missed those things
https://linustechtips.com/topic/1492105-first-build-help/#findComment-15829045
It was also in November so some of the stuff you are looking for is probably less expensive now. Personally what I did for power supply was look to see what if any power supplies that are reputable and meat the system requirements were on sale.
So it's a way to not cheap out but maybe save $10 dollars + which is definitely nice when you are spending over $100 dollars.
https://linustechtips.com/topic/1492105-first-build-help/#findComment-15829711
Yeah I’ve been looking on eBay for a used cpu or gpu and there are some pretty good prices that are less than 300 dollars
https://linustechtips.com/topic/1492105-first-build-help/#findComment-15829779
On 3/5/2023 at 12:06 AM, habidtenly said:
thanks! i found out i would have to get an adapter for it and i picked a smalller one the u12s
Noctua would ship the D15s and U12s with the 1700 mounting bracket.  The included hardware and 6- year warranty are part of the reason for the higher price.  The D15 is their top performer but takes up a lot of space over the mobo. The U12A is #2 and doesn't overhang but requires a wide case. The difference between it and the U12S is that it has 2 fans instead of one, more heatpipes in a different configuration, and a different fin array (see next post for details). There are several other coolers that are comparable to these, such as the aforementioned Assassin. Deep Cool, be quiet! and a few other companies also offer 1-2 great coolers.
Edited by RevGAM
Noted correct info in next message.
I've been using computers since around 1978, started learning programming in 1980 on Apple IIs, started learning about hardware in 1990, ran a BBS from 1990-95, built my first Windows PC around 2000, taught myself malware removal starting in 2005 (also learned on Bleeping Computer), learned web dev starting in 2017, and I think I can fill a thimble with all that knowledge. 😉 I'm not an expert, which is why I keep investigating the answers that others give to try and improve my knowledge, so feel free to double-check the advice I give.
My phone's auto-correct is named Otto Rong.🤪😂
https://linustechtips.com/topic/1492105-first-build-help/#findComment-15829860
On 3/5/2023 at 4:27 PM, RevGAM said:
Noctua would ship the D15s and U12s with the 1700 mounting bracket.  The included hardware and 6- year warranty are part of the reason for the higher price.  The D15 is their top performer but takes up a lot of space over the mobo. The U12A is #2 and doesn't overhang but requires a wide case. The difference between it and the U12S is that it has 2 fans instead of one. There are several other coolers that are comparable to these, such as the aforementioned Assassin. Deep Cool, be quiet! and a few other companies also offer 1-2 great coolers.
Correction regarding the U12S vs A. According to Hardware Canucks, the fin array is denser on the A.
https://youtube.com/clip/UgkxNkIeD_FD0kVFBGrH03dvM2svQg59LLRf
In looking at the Noctua comparative text, it's mostly just marketing words and the chart doesn't talk about the differences between the two arrays. The chart does indicate with their NSPR score that the U12A (regular and chromax.black) is very significantly better than the other versions. However, when I look at the photos of the U12A and the U12S, I can definitely see that not only are the arrays different, but so are the heatpipes. Additionally, the number of heatpipes (per side) and the type of fans are different, with the U12A being $40 more. As a note, chromax.black costs about $10 more. The NH-U12L sits comfortably between the two, offering better performance, better fans and twin heatsinks than the U12S. You can add a second fan to the S, L and redux versions, but I suspect that it would be more valuable on the L than the others given the twin towers.
I was surprised by all of this, and I apologize for providing incorrect info.
https://linustechtips.com/topic/1492105-first-build-help/#findComment-15838100
