CPU Light Red, No Display output
Go to solution Solved by 191x7,
29 minutes ago, spinnna said:
So i just put together a new PC and i dont seem to get any display output. It seems to boot just fine and i dont recieve any POST codes, i did notice that the CPU light on my MOBO is illuminated in red.
These are my specs
MSI Pro Z690-A
650W PSU
3060 Ti
i5 13400F
DDR5-4800 RAM
Things i tried so far :
Removing the GPU and plugging display cables straight in the MOBO
Removing and inserting the CMOS Battery
Placing the RAM Modules in different slots and running it with only 1 module
Did you flash a compatible bios?
A 13th generation CPU can't work on a 600 series motherboard unless a compatible bios (or newer) is flashed.
These are my specs
MSI Pro Z690-A
650W PSU
3060 Ti
i5 13400F
DDR5-4800 RAM
https://linustechtips.com/topic/1491539-cpu-light-red-no-display-output/
These are my specs
MSI Pro Z690-A
650W PSU
3060 Ti
i5 13400F
DDR5-4800 RAM
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
usually having the cpu led on is an indication that it has not got past initiating the cpu, therefore it has not booted.
as mentioned by 191x7...bios
if its on compatible bios then
check cpu socket for anything wrong, bent pins etc
loosen off cooler slightly
but lets hope its just the bios
  • 1 month later...
These are my specs
MSI Pro Z690-A
650W PSU
3060 Ti
i5 13400F
DDR5-4800 RAM
I am having similar issues, but with a 700 series board. CPUs are the part that the sucks the most about PC builds.
