Build Help
Go to solution Solved by SpecTre12345,
12 minutes ago, thawea said:
Other details:
- probably going to buy parts at the end of August
Come back then and we can provide you with a more accurate list. Any recommendations made now will be invalid by August.
1. Budget (including currency): 4000 CAD
2. Country: Canada
3. Games, programs or workloads that it will be used for:
I will use it to mainly play fps games such as Valorant and Overwatch 2. I would also like to do some light coding, video editing, rendering, and music production on the PC.
3. Monitors
One 1080p 240hz monitor, which I will use for gaming and another 1440p monitor which I will use for work.
4. Peripherals
I would like some recommendations on headphones that could be used for gaming but also have good audio quality for music production. If the budget allows, please recommend me some speakers and mic as well. I already have a pretty good keyboard and mouse, so don't worry about those.
5. Why are you upgrading?
Currently I use an Alienware laptop with a i7 8th gen and rtx 2060. So I thought it might be time to finally switch to desktop.
Other details:
- going for a white themed build, if possible
https://linustechtips.com/topic/1490205-build-help/
Other details:
https://linustechtips.com/topic/1490205-build-help/#findComment-15815355
