Hello, I'm trying to upgrade to a 4090, but I have several issues that I need to help with figuring out before I make any purchase.
1- I have a Corsair icue 5000x case and in terms of length (max gpu length for the case is 400mm), a 4090 will fit just fine, but the problem is with the height since I need 35mm of clearance before any bend on the cable. The case says it has 170mm of CPU cooler height clearance, but I don't know if that applies to GPU height as well.
2- since I need 35mm of space just for the cable and no 4090 out there is shorter in height than 140mm, 140+35= 175mm and assuming the max cpu cooler height for the case is the same as the GPU, i'll be about 5mm short not matter what so I'll need to use a 90 degree adapter from cablemod.
3- the 90 degree adapter from cable mod does not mention the MSI RTX 4090 gaming X trio (shortest 4090 I can find in terms of height besides the founders edition) as compatible on the store page for the adapter, but it does mention it in the compatibility list, so can I use this adapter with an MSI RTX 4090 Gaming X trio or not? https://store.cablemod.com/12vhpwr-angled-adapter/     if I can, then which variant am I suppose to get for the MSI RTX 4090 gaming X trio? Variant A or Variant B?
4- I have a Corsair HX1200w PSU and I have to get this cable https://www.corsair.com/us/en/Categories/Products/Accessories-|-Parts/PC-Components/Power-Supplies/600W-PCIe-5-0-12VHPWR-Type-4-PSU-Power-Cable/p/CP-8920284
Will this cable work fine with the cablemod 90 degree adapter that I linked along with my Corsair 1200w PSU? I know this might sound like a dumb question, but I really need to make sure since making mistakes with this kind of stuff can cause some real damage. Thanks in advance.
https://linustechtips.com/topic/1489826-4090-upgrade-problem/
If this is the one you're talking about, then yes:
Gaming PC:
CPU: Ryzen 5800X3D | Motherboard: Gigabyte B550 Elite V2 | RAM: Crucial 2x16gb, 3200  JEDEC. | PSU: EVGA SuperNova 750 G3 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: Asus Prime RTX 5070ti OC| Sound: Odac + Fiio E09K | Case: Fractal Design R6 TG Blackout |Storage: Kingston Renegade 2TB and Corsair MP510 960gb | Cooling: CPU: Alphacool ST30 420mm rad, Alphacool CPU and GPU Core LT and Core blocks, D5 pump and res combo
Linux PC:
CPU: Ryzen 7700| Motherboard: Asus A620M-CSM | RAM: Crucial Pro 2x48gb, 5600  JEDEC. | PSU: Corsair CX750 | Monitor: LG 27GL850-B , Samsung C27HG70 |
GPU: MSI Gaming X RTX 3090 | Case: Lian Li Dan Cases A3-mATX black |Storage: SN7100 2TB + Samsung 860 EVO 512gb | Cooling: CPU: Thermalright Peerless Assassin Mini Fan(s): Noctua 1x NF-A14x25 Chromax
https://linustechtips.com/topic/1489826-4090-upgrade-problem/#findComment-15812193
yes it will work with the Corsair type 4 12vhpwr cable I linked? or yes it'll work with an MSI 4090 gaming X trio? if so which variant? A or B? Can both the 90 degree adapter along with the Corsair cable work together with my PSU? is there any downside with using the corsair cable and the adaptor together? does the cable even work with my psu?
https://linustechtips.com/topic/1489826-4090-upgrade-problem/#findComment-15812221
I see. As usual i didn't read thread properly :u..
If anything fits it should be B. But I see. its very har to see if you got clearance. I would check with calipers before buying:
Gaming PC:
Linux PC:
https://linustechtips.com/topic/1489826-4090-upgrade-problem/#findComment-15812228
Won't a vertical GPU mount solve many issues there ?
The Corsair 5000 is pretty spacious I think the card would still be able to breathe a bit
https://linustechtips.com/topic/1489826-4090-upgrade-problem/#findComment-15812256
I've never mounted a gpu vertically nor do I really want to learn how to mount an expensive card vertically for the first time. I just need answers for the questions I asked in my opening post.
https://linustechtips.com/topic/1489826-4090-upgrade-problem/#findComment-15812368
The compatibility list says Variant A
"MSI Gaming X Trio 4090    90 Degree Variant A (backplate side), 180 Degree Variant B (backplate side)"
while the Variant A store page itself doesn't mention MSI gaming X trio, but mentions that it supports other cards. The Gaming X trio isn't on the B variant store page either.
That's why I'm confused.
https://linustechtips.com/topic/1489826-4090-upgrade-problem/#findComment-15812384
Wut I can't see it. Link?
Gaming PC:
Linux PC:
https://linustechtips.com/topic/1489826-4090-upgrade-problem/#findComment-15812391
https://store.cablemod.com/compatibility/
scroll down to  "12VHPWR 90/180 Degree Angled Adapters"
if you go to the main page for the adapter itself, it doesn't mention MSI 4090 gaming X trio at all. scroll down to right under where it says "awesome styling"
https://linustechtips.com/topic/1489826-4090-upgrade-problem/#findComment-15812394
Ok it was a suggestion for an innovative solution 😛
Mounting a GPU vertically is basically the same than horizontally, just need an extra adapter...
https://linustechtips.com/topic/1489826-4090-upgrade-problem/#findComment-15812398
Arh I see. I just looked at the product page. 🙂 Then Yes it's supported as they say it is.
Gaming PC:
Linux PC:
https://linustechtips.com/topic/1489826-4090-upgrade-problem/#findComment-15812400
Sorry I edited my post after you commented already. I was saying, MSI 4090 gaming x trio is listed here for Variant A https://store.cablemod.com/compatibility/
but not here https://store.cablemod.com/12vhpwr-angled-adapter/ for the part where it lists compatible cards.
https://linustechtips.com/topic/1489826-4090-upgrade-problem/#findComment-15812408
https://linustechtips.com/topic/1489826-4090-upgrade-problem/#findComment-15812439
