Fan Filters?
Go to solution Solved by Saladin,
Sweet cause I was looking at getting fan filters for my Ethoo Primo, I am not a huge fan of the front and bottom fan filters that it has
They should fit well with that case. You shouldn't have any problem finding 120/140/240 mm filters on frozenCPU. The nice part about them is that all you have to do to clean them is to run some water over them, wipe with a towel and then let them dry (or dry them with a paper towel), because they are magnetic there are no screws or clips to worry about, you just slap them back on. If you have a case that is non magnetic (aluminum or plastic) the filters come with an included magnetic strip with adhesive on it to stick to your case. Hope this helps.
I'm looking at getting aftermarket fan filters just to see if I get any improvement with the dust that some how ends up in my system still.
Any recommendations?
I've been looking at http://www.demcifilter.com/ and cant find to much on it atm
|King Of The Lost|
Project Dark: i7 7820x 5.1GHz | X299 Dark | Trident Z 32GB 3200MHz | GTX 1080Ti Hybrid | Corsair 760t | 1TB Samsung 860 Pro | EVGA Supernova G2 850w | H110i GTX
Lava: i9 12900k 5.1GHz (Undervolted to 1.26v)| MSI z690 Pro DDR4| Dominator Platnium 32GB 3800MHz| Power Color Red Devil RX 6950 XT| Seasonic Focus Platnium 850w| NZXT Kraken Z53
Unholy Rampage: i7 5930k 4.7GHz 4.4 Ring| X99
Rampage|Ripjaws IV 16GB 2800 CL13| GTX 1080 Strix(Custom XOC Signed BIOS) | Seasonic Focus Platinum 850w |H100i v2
Revenge of 775: Pentium 641 | Biostar TPower i45| Crucial Tracer 1066 DDR2 | GTX 580 Classified Ultra | EVGA 650 BQ | Noctua NH D14
https://linustechtips.com/topic/148877-fan-filters/
@KingCry Demciflex Magnetic Fan Filters. Accept no substitutes. They are phenomenal, really easy to clean, really easy to install. They will custom make anything, if you need that. You can get some of their stock stuff from FrozenCPU.com
Intel 3570k @ 4.4 GHz |Asus Sabertooth Z77 |EVGA GTX 660 Ti FTW |Kingston HyperX Beast 16 Gb DDR3 1866 (2x8Gb)
|Samsung 840 250 GB |Western Digital Green 2TB 2x |Cooler Master 850w 80+ Gold |Custom Water Cooling Loop |Noctua NF-F12 4x
|Noctua NF-A14 3x |Corsair Carbide 500R (White) |Corsair K95 |Razer Mamba |Razer Megalodon |Samsung SyncMaster T220 2x Computer Bucket List   Greatest Thread Ever   WAN Show Drinking Game  GPU Buyers Guide
https://linustechtips.com/topic/148877-fan-filters/#findComment-1989128
|King Of The Lost|
https://linustechtips.com/topic/148877-fan-filters/#findComment-1989165
https://linustechtips.com/topic/148877-fan-filters/#findComment-1989179
