Key cap help
Solved by NF-A12x25,
Romer g caps are very difficult to find especially in a taller profile. I would just bind moving keys to something you can reach better, but you can also find a Romer G adapter to Cherry MX keycaps and then get a tall keycap, ideally an SA or similar ESC cap- since the escape key/fn row is the tallest.
You can 3D print this or get someone that has a 3D printer to do so, then find an SA profile esc cap.
https://www.thingiverse.com/thing:4658101
Or, you can 3D print a customizable romer g cap
