first build since 2011
Go to solution Solved by Queen Chrysalis,
A lot of this could be done away with without any real hit to performance.  For what you wanna play this would get you there far more cost effectively:
  • 13900k is meme-tier overkill.  The i5 already has 14 cores, you'll never use all of them, let alone how ever many cores the 9 has.  And they're the same cores. It'll boost to almost 5GHz with PBO enabled.
  • Same goes for 64GB of RAM.  32GB is already way more than enough.  I did DDR5 in this because you seem keen on spending a lot on this, but frankly DDR4 would owrk the same.
  • z-series motherboards are kinda pointless now that precision boost will take your CPU to it's max frequency more efficiently and with better temps without overclocking.  You can barely see the graphics on this one when the cooler is installed, but frankly I think it looks cool with the case and GPU.
  • For DDR5 RAM 6000MHz is worth it.
  • 7900XTX is a better value than the 4080 and it will be better in newer games with how much VRAM it has.
  • The corsair RMe series use inferior caps to the regular RM.  This bequiet unit is only 20 pounds more and it's overall a better buy.
  • I could not find that case PCPP, but if you really want iit go for it, but you can spend a lot less on the case.  But it's just a taste thing.
  • Three screens is probably not where it's at, but if you want it go for it, no big deal.  If it were me, I'd prefer a single ultrawide.  It's quite immersive.
PCPartPicker Part List
CPU: Intel Core i5-13500 2.5 GHz 14-Core Processor  (£242.25 @ Amazon UK)
CPU Cooler: Alpenföhn Dolomit Premium 54.5 CFM CPU Cooler  (£67.89 @ Amazon UK)
Motherboard: ASRock B760M PG SONIC WiFi Micro ATX LGA1700 Motherboard  (£166.00 @ MoreCoCo)
Memory: Kingston Renegade Silver 32 GB (2 x 16 GB) DDR5-6000 CL32 Memory  (£157.48 @ Ebuyer)
Storage: Kingston KC3000 2.048 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (£157.99 @ MoreCoCo)
Video Card: PowerColor Hellhound Radeon RX 7900 XTX 24 GB Video Card  (£1087.98 @ Overclockers.co.uk)
Case: Aerocool Aero One Mini Eclipse MicroATX Mini Tower Case  (£56.99 @ Amazon UK)
Power Supply: be quiet! Pure Power 11 FM 1000 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  (£158.22 @ Amazon UK)
Monitor: LG 34WP65C-B 34.0" 3440 x 1440 160 Hz Curved Monitor  (£395.96 @ Laptops Direct)
Total: £2490.76
Generated by PCPartPicker 2023-02-15 22:24 GMT+0000
Budget (including currency): £6500
Country: England
Games, programs or workloads that it will be used for: racing sim, fps games and streaming.
this will be a complete new build and my first since 2011. i have since been gaming on console's ps and xbox and i feel some what restricted now. i am looking to get back into pc gaming and sim racing. i am also thinking of streaming some of my gaming sessions.
the build i a looking to do: CASE - HYTE Y60 or 1st Player Steampunk SP7
                                          Processor - i9 13900KF
                                          ram - 64bg DDR5  Kingston Fury 5600mhz 2x32
                                          mothetboard - ASUS PRIME Z790-P WIFI ATX
                                          GPU - PNY GeForce RTX 4080 16GB VERTO
                                          M.2 - ADATA XPG GAMMIX S70 BLADE 1TB PCIe Gen4x4 M.2 2280 SSD
                                          HDD - seagate 4TB barracuda
                                          AIO - MSI MPG CORELIQUID K360 CPU AIO Cooler
                                          PSU - Corsair RM1000e 1000W Fully Modular 80 Plus Gold Power Supply
 peripherals: monitor - AOC Gaming G2490VXA 144hz x 3
                     msi gaming mouse and wired keyboard
                                    next level racing f-gt cockpit
                                    moza r16 wheel base
                                    moza fsr formula wheel
                                    moza CRP peddles
                                    50inch samsung tv for the racing sim rig
streaming gear will come later when i have got use to pc gaming once again lol.
now i have listed the build do you think there is anything different i should do or change. it all falls into the budget(just).
i am looking to purchase this lot in the next month or 2.
cheers in advance
https://linustechtips.com/topic/1488449-first-build-since-2011/
Does 64GB of RAM help you at all? IMO it's kind of overkill.
I'd go for an ultrawide long before I'd go for three separate monitors, especially for what you're doing. Why have to deal with the black bars?
Is the HDD for mass storage? I wouldn't put games on it. Your budget should allow you to have at least 2TB of SSD storage for games.
Generally it's best to wait until you're ready to build, before asking for advice. Pricing and availability can change quite significantly even in a small space of time like that.
Welcome to the forum.
MiniPC - Sold for $100 Profit
OG Gaming Rig - Gone
https://linustechtips.com/topic/1488449-first-build-since-2011/#findComment-15802406
Total: £2490.76
I edit the shit out of my posts.  Refresh before you respond.
https://linustechtips.com/topic/1488449-first-build-since-2011/#findComment-15802418
  • 9 months later...
hi all, I finally decided on my build.
I went with - corsair 5000D AIRFLOW
                      I7 13700kf
                      gigabyte aero RTX 4070ti
                      64gb ddr4 corsair vengeance rub pro 3600
                      corsair 2TB MP600
                      ASUS ROG Strix 850w
                      EVGA CLCx AIO 360mm
I decided to go for a more expensive rig for my sim racing set-up
V-RIG multi position sim racing rig
MOZA R16
MOZA FSR steering wheel
MOZA gear shifter H BOX
MOZA Handbreak
ASETEK Invicta peddles
I also have 49 inch ultra wide Asus monitor for sim racing
I use a 49 inch QLED tv for normal gaming and 2 x 27inch koorui monitors(one as a hardware monitor and the other as an over head display for the slim rig.
https://linustechtips.com/topic/1488449-first-build-since-2011/#findComment-16218449
