PSU Cable
Go to solution Solved by IkeaGnome,
6 minutes ago, DomProNet said:
Do any of you guys know where I could get a sata cable for a Corsair CX500f on amazon, I got a prebuilt pc with it and I want to expand my storage
Any corsair type 3 or type 4 sata cable will work.
https://www.corsair.com/us/en/psu-cable-compatibility
Type 3 and type 4 are different, but only in the 24 pin cable. Sata cable will be the same.
Quote
Disclaimer: The only difference between Type 3 and Type 4 cables is the pinout of the 24-pin ATX cable; all other cables (SATA, PCIe, etc) are the same.
https://www.amazon.com/Corsair-CP-8920186-Premium-Individually-Sleeved/dp/B01N7HEVM7
Quote
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
https://linustechtips.com/topic/1487387-psu-cable/#findComment-15794465
Thanks
https://linustechtips.com/topic/1487387-psu-cable/#findComment-15794489
