CPU stuck on base frequency
Solved by HardStroke,
6 minutes ago, Eterna said:Upgraded from an i5-9400F
I have reset bios 3 times
Be quiet! Pure Rock Slim 2 is the cooler
ASRock H310CM-HDV is the motherboard
This poor little motherboard is not built to hold a fully clocked 9700k
Its not enough to hold it
83c is really high for a 9700k
The board can't supply enough power for the chip so it just stays at 3.6GHz
It doesn't have the capabilities to give it that extra power for that turbo 4.6GHz clock
If I was in your place I'd repurpose that motherboard as a cutting board and get a used z390/z390 motherboard to let that chip really "breathe"
Good thing you didn't get a 9900k with that board...
