Sufficient cooling?
Go to solution Solved by 191x7,
9 minutes ago, UnknownWallsTwitch said:
Is the Deepcool ak400 zero black enough for a ryzen 5 5500 that will be overclocked?
Yes it is.
Already have the Ryzen 5500? If not, the 5600 is a lot stronger CPU.
The 5500 lacks a good amount of L3 cache, doesn't have PCI-E 4.0 - it's a 5600G without the iGPU and it performs between a Ryzen 5 2600X and 3600X, similar to a 3600.
But the 3600 and 3600X have PCI-E 4.0.
Yes it is.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
https://linustechtips.com/topic/1486648-sufficient-cooling/#findComment-15788741
Between a 3600 and 5600 you mean
And gen4 doesnt even matter anyways unless you are getting a crappy 6500 xt
If the 5500 is 30$ cheaper then 5500 is preffered, you can make it perform similarly to a 5600 by running rams as close to or at 5000mhz (1:1 infinity fabric) and doing a 4.6-4.8g overclock
Cooler wise just get a peerless assassin, problably similarly priced anyways, if not theres the assassin king and burst assassin for cheaper options
https://linustechtips.com/topic/1486648-sufficient-cooling/#findComment-15788838
No, I mean exactly as I wrote, between the 2600X and 3600X. PCI-E 4.0 matters not just for GPU-s but for NVME SSD-s too.
And also the 6600XT and 6650XT GPU-s are PCI-E 4.0 8-lanes so they get a small performance penalty when running on a PCI-E 3.0 board.
Infinity fabric isn't running at 5000 MHz. And for Zen2/Zen3, the CPU-s perform the best when it's synced with the RAM (1:1) at 1800 (3600mhz) but 1600 (3200) is also fine.
https://linustechtips.com/topic/1486648-sufficient-cooling/#findComment-15788860
The imc is a ton better on cezzane, infinity fabric should go around 2500 ish so 5000 ddr4
and non apu ryzens theyll do somewhere around 3800-4000 for 1:1
You got any like reviews comparing the 5500 to the 2600/3600? Afaik the 5500 beats the 3600 but falls behind the 5600 obviously
And directstorage isnt a thing yet, even if it was whats the diff between 5 seconds and 3 seconds? Its not gonna be massive like going from an hdd to a sata/nvme ssd, though maybe its more useful for massive games than just loading windows. Only reason to get a gen4 is if you do r/w heavy stuff like high res video editing or gen4 is so cheap you may aswell get it (well assuming its dram, cause a highend dram gen3 will still crush the gen4 over longer r/w)
https://linustechtips.com/topic/1486648-sufficient-cooling/#findComment-15788881
8 hours ago, 191x7 said:
Yes it is.
I already purchased all my components, and was wondering because I am using stock cooler right now.
I try to be a human, but I cannot, because I have returned to monke.
Hehe boi
POV- when it can run crysis-
 ( ͝° ͜ʖ͡°)
https://linustechtips.com/topic/1486648-sufficient-cooling/#findComment-15789241
Yeah I had a smol budget
Hehe boi
 ( ͝° ͜ʖ͡°)
https://linustechtips.com/topic/1486648-sufficient-cooling/#findComment-15789243
