90c CPU, help finding new mounting hardware
Is RMA an option?
https://www.reddit.com/r/lianli/comments/v712l0/lian_li_galahad_240_aio_not_functioning_like_it/
Honestly for R 5 5600x a 2nd hand/cheap Wraith Prism is a good enough air cooler (both in terms of cooling and looks, just a bit noisier).
In case you end up RMA-ing your AIO you can find Wraith Prism for 15$ and use that till you get a replacement, or if you just wanna test if the issue truly is with the mounting / AIO.
1 hour ago, Drexl said:My best guess is that crappy two-point mounting system is the issue. It's probably not getting even/enough pressure.
That would be my guess as well.
1 hour ago, Drexl said:I re-pasted the CPU on one of the machines and that improved it enough to prevent issues in games, but obviously 90c is too high.
Have you tried with a different paste, or least different batch of paste?
I've personally had Thermal Grizzly Kryonaut degrade in just 2 days (probably because it breaks down at 80c...) and I've had NT-H2 degrade after 7 days (bad batch I guess)... And it wasn't a mild performance drop, talking about 12-14c higher temps.
Ended up using "be quiet DC1" (which truly is not special in any way), and sure it was worse about 2c from the start but it didn't degrade (about 9 months now I think).
Edit: (forgot to reply to this part)
1 hour ago, Drexl said:is it possible purchase a better mounting solution for this hardware?
Not that I am aware of.
