It does support GTX 1650SUPER also. But the perfomance wont be there if you could save up that the best thing you could do rather than waste moeny on 1650. 1650 isnt a great card but CPU will bottle neck. if you are buyying a new 1650 for 200$ save that money. If you just want to use as a video output cheaper cards do the job.
https://linustechtips.com/topic/1486053-help/#findComment-15784637
